Question about HP DeskJet 5652 InkJet Printer
My printer only prints part of a photo then prints next part on a different sheet of paper. Each time it prints you get a smaller or larger portion of your photo.
    Sergeant:
  • 207 Answers
Check your printer properties before printing especially the size of the paper that is set on your printer options.
Posted on May 27, 2011
My Officejet 4500 does not eject a printed page fully, causing the next page to overprint the bottom of the previous page.
Sounds like the printer is set up to print a smaller size paper than the sheet size you are actually using. Measure your paper size, then go into the printer settings and choose the sheet size that matches.
Oct 20, 2014 | HP Officejet 4500 All-in-One Inkjet...
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
I want to print on photo paper I have no idea how to start,printer is a photosmart 7450
OK, Assuming you have Photo paper loaded in your printer and your photos from your camera downloaded to a photo software program. eg Adobe Photoshop/ Serif Photoplus etc.
Bring up the photo/photos you wish to print on your photo software. eg click on the open yellow folder top left and open the fotos you want.Click 'Browse' if you don't see the ones you want. ( Open as many as you want to print.)
In order to make your prints economical you can print two or three fotos on one sheet. Click 'File', 'Print multiple' and you will see format sheets in the right pane. If you only want to print two pics on one sheet click in the right pane on the two 7 x 5 sheet or, to print three pics of the same or different pics click the sheet with three frames on it. You will now see your pictures in the right hand frame and the format sheet in the right hand frame.
Left click and hold on the pic you want and drag it into one of the boxes in the right hand frame - let go.
That pic will now appear in the box selected. you can now size it to the box it is in. If it is the right way up eg portrait in top left of a three frame page click on fit to frame to maximise picture. Click and drag another pic from the left side frame to another box in the right frame. If you have chosen the three option sheet click and drag your next foto into the bottom box on the sheet. This is a Landscape box but don't worry.
After dragging your pic into it look for an icon in the function bar along the top where, when you hover your cursor over it, says - 'rotate and fit'.(It's a square with funny corner bits!) Your pic will the be realigned to fit the the box. Having all the pics you want on the sheet click the print icon. (Picture of a printer on the tool bar.) when the print box appears click on 'Properties' and open the 'Paper/quality' tab. click the drop down box for paper and select HP Photo paper - gloss or whatever you are using. The quality will automatically set to 'Best'. Click OK and OK and the files will be transferred to your printer and it will shortly start printing your pictures.
Bset of luck.
Any problems at all, just get back to me.
Cheers.
Ian
Dec 01, 2009 | HP Photosmart 7450 InkJet Printer
Need to change my print size on my C6280 Photosmart All-in-one printer, make it larger
It depends on what you are printing, but generally this needs to be adjusted in the software you are using.
If you print pictures or photos, you have to find an option to scale the printout up, either during printing, or beforehand.
If you print PDF documents, in the Print dialog box there is an option to "fit printer margins" or "auto-adjust to printer size" or something to that effect in every PDF reader application. If however the document is formatted for your paper size it will not be scaled, and if it's formatted for an even bigger sheet size, it will scale down the printout.
If you print documents from Word, there's no easy way to make the printout bigger - you can change the font size to a larger one in the whole text, but chances are, that this will ruin the text formatting.
In Excel there is an option to scale everything by a given percentage, which will automatically tile the table into as many sheets as necessary. and then the area will be printed on as many paper sheets as necessary to get
There's no one solution, unless your printer driver has an option to do a fixed scaling - but this will usually be sensible only for enlarging printouts that occupy a smaller area on paper, and you want them to use the maximum paper area. I'm sorry, but you have to experiment a bit to get the hang of it.
Nov 12, 2009 | HP Office Equipment & Supplies
Black text printing not using large cartridge
Change your setting to plain paper and normal quality.
This printer uses the small black for photos and high qau;ity papers.
Do this and you should be good to go.
Jun 28, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon R265 keeps grabbing 6 sheets for printing one sheet
Paper has different thicknesses called Mils. Make sure you are using the correct paper for your printer. Paper that is thinner than is intended for your printer may sometimes cause it to take multiplesheets.
Jun 15, 2009 | Epson Stylus R265 InkJet Photo Printer
Paper Feed Problem
I had same problem... eventually just started using 8.5 X 11 paper to print photos with smaller sizes.
Mar 30, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing photos
That is called pixelation and is usually the result of enlarging a photo, whether it be resized larger on the computer or printed at a larger size than it's original pixel dimensions.
Check your printer settings for a setting like "resize photo to fit paper" and uncheck it. Or print from a photo that is larger than the paper and it will reduce the size without any pixelation.
With digital photos you can always go smaller than the original, but rarely ever larger.
Feb 17, 2008 | Epson CX8400 All-In-One InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
