Question about Frigidaire FMT116E1W Microwave Oven
Frigidaire FMT116E1W - Issue
We have the FMT116E1W microwave. When plugged in, the fan starts to run, and the interior light goes on. These never go off. I can set the clock, turn on/off the exhaust and over the stove light, but thats it. Nothing else seems to work.
We just recently bought a house with this unit installed, so I'm not sure about what could have caused this. The original owner didn't know either. Any help, or suggestion, will be greatly appreciated. I'd hate to buy a new one if I don't need to.
  • Anonymous Sep 25, 2008
    you have to puch the door and hold it push and see if it works if it works you have to adjust the switch bracket
  • Frigidaire Master
  • 9,174 Answers
I suspect a problem with a door switch mount, but here is my full standard reply on this symptom:
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 18, 2008
SOURCE:
I unplugged my aunt's microwave to clean it, when I plugged it back on the light inside is on and the plate turns and the fan goes, cannot do anything with it, can't cancel or start, only way is...
Likely when you cleaned it, grease mixed with the cleaner you used got between the button panel and the actual button switch behind the panel, making it stick on. Will need the model to determine how to remove the panel to clean underneath...OR, it may dry out and start working normally again.
Nov 03, 2017 | Frigidaire FMV145K Microwave Oven
I have a FMT116E1W made a loud pop and now no power or anything.
This sounds like the magnetron has failed, the pop sound is a classic sysmptom.
May 18, 2012 | KitchenAid KHHS179LSS Convection /...
Fmt116e1w microwave not heating, how do I fix
The problem may be a defective magnetron, or the inverter board, { if 7 years old or less } keep in mind these are pricey parts,
May 15, 2012 | Frigidaire Microwave Ovens
No power at all checked fuse yd ok
The problem is the inverter board,"if 7years old or less" or the keypad control board.
Apr 25, 2012 | Frigidaire FMT116E1W Microwave Oven
Rmicrowave runs but does not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 03, 2011 | Frigidaire FMT116E1W Microwave Oven
I do not have the manual. How do I change the poiwer level on a Frigidaire Microwave model FMT116E1W
After setting the time amount before you hit the start button, push the power button with each push it should indicate a different power level if not you've got to use the keypad, for example, 50 is 50% power etc.
Sep 07, 2009 | Frigidaire Microwave Ovens
Microwave Ovens Logo
209 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
