Question about Breville Fresca BES860 2Cup Coffee Maker
Water coming out of the filter when making coffee. It would seem the rubber seal has worn out. I tried putting less coffee in the filter. It works sometimes.
    Novelist:
    Champion:
  • 232 Answers
It is possible that you have found your own solution, I have found that this unit works best when the tamped coffee sits between 3-5mm below the rim. Don't forget that this unit pre presurises the basket before operation. If it has to much coffee in there it is possible that there is to much pressure that it is escaping the seal.
Posted on Jul 29, 2011
My Rancilio Silvia won't pump water out of the head all of a sudden. It had worked for years up to this point
It may be that the 'shower screen' which is a perforated metal disk filter that fits inside the head has reached its use by date.
These can be found and bought on E-bay for about $15 each, make sure you buy a genuine Rancilio replacement, while you are at it, replace the rubber 'group seal' - a rubber ring for pressure sealing the head/arm after filling the arm with grounds - these are a similar price. If you get leaks around the head while making a coffee, the seal is worn out.
Jul 31, 2013 | Rancilio Silvia Espresso Machine
I have the Krups 964 espresso maker; it is about 10 years old. Recently it began to pour water out and around the coffee basket holder at a fast pace, and it does not make expresso. I did remove the...
I don't know much about this unit, but there might be a rubber seal in head where the porta filter locks in to. It is possible that this seal is either damaged or just corrupted with grounds. Try cleaning it out and or checking the seal for damage.
Sep 10, 2011 | Coffee Makers & Espresso Machines
Water pours out from all around when making coffee. I fill the filter with coffee and turn the machine to brew and water seems to overfill and comes out over the top.
Theres a seal from the machine to the handle or porta filter its acalled a group seal it is worn or dried up solution is to replace the seal
Dec 16, 2009 | Breville ESP8XL Espresso Machine
Maxkon SK 201A Coffee machine only has one rubber pipe
hi - had same prob= found out modern maxcon machine has only one tube in water tank- other is internal. turn steam knob to off position- anti clock - and wait till water / coffee light is green- then water will come out from filter . when wanting the steam- turn the steam knob clockwise - hope this helps - susan
Jun 27, 2009 | Coffee Makers & Espresso Machines
I have to hold the filter when making coffee - if I don't the filter holder starts to unwind and then coffee and water spurts everywhere. It has only just started this and I clean it constantly making...
Please check the following:
1. Hooks - the hooks could be worn
2. Gasket - it could be worn or broken.
You need to replace the filter holder or the rubber seal/gasket.
Hope it helps and have a great day!
Jun 16, 2009 | Coffee Makers & Espresso Machines
My Breville800ESXL makes steam but does not make espresso.
jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Nov 19, 2008 | Breville Die Cast 800ESXL Espresso Machine
Leaking coffeemaker
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Jul 21, 2008 | Cuisinart DGB-600 Coffee Maker
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Everything seems to work but no coffee
take down the machine and change rubber seal for the water reseviour and the nozzle they are brikley.good luck.it also needs a good cleaning there after.
Apr 25, 2007 | Saeco Magic De Luxe Espresso Machine
After using coffee that was too small, I can't make coffee with one of the filters
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Apr 10, 2007 | Breville ESP8XL Espresso Machine
Breville Fresca BES860 2Cup Coffee Maker Logo
51 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
