Question about NAD C326BEE Amplifier
NAD C326BEE amp problem. Connected to recommended Wharfdale speakers and NAD CD player and previously working fine for a year. Now red light flashing on amp and no sound when system is turned on.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
http://nadelectronics.com/products/hifi-amplifiers/C-326BEE-Stereo-Integrated-Amplifier
Page 6 and 13
Posted on May 27, 2011
I need a circiut diagram for nad c326bee so that i can repair this unit
www.eserviceinfo.com would be one suggestion. good luck. it is in PDF format. good luck.
Nov 20, 2014 | NAD C326BEE Stereo Integrated Amplifier
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
My NAD C326BEE amp goes into protection mode at moderate volume
The protection only should come on, when the power amplifier has to give more current than it can deliver. (electronic fuse)
If in the music is a lot of subsonic, sound, so low you can't hear and your speakers can't produce, this could cause the problem. Normal CD players will cut of all frequencies beneath 20 Hz, but it could be your PC is giving everything from 1 Hz and above.
I would certainly try to play some music over a CD player and check if that would solve your problem. Not sure if that works, what you could do to suppress the sub sonic in the computer music.
Aug 22, 2012 | NAD C326BEE Amplifier
Nad c320bee keep over heating
Hello
Disconnect all speakers and switch ON the set without any input connected, and see whether it heats up. A moderate heat is permissable, but should not over heat. If it overheats without any load or input connected, the set need service. OK.
Jan 19, 2012 | NAD Audio Players & Recorders
I plugged in my Nad amp to a socket last night, there was a flash of blue light and now it won't switch on. It is a NAD C316BEE Stereo Amplifier. Can you advise what has happened?
You need only look inside and follow your nose....The smell will lead you the faulty party, probably in the power supply. Just a power surge problem or something that's been going giving up the ghost.
Sep 06, 2011 | NAD C326BEE Amplifier
I OWN A NAD M 25 ---7 CHANNEL AMPLIFIER. I AM USING 4 CHANNELS TO BIAMP MY SPEAKERS. ONE OF THE UNUSED CHANNEL IS SHOWING A RED PROTECTION LIGHT.THE BIAMPED CHANNELS ALL WORK FINE ...I HAVE CHECKED ALL...
The manual would suggest you have a problem.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-M25-Amps-manual/id/8043ci561/t/2/
Try unplugging all of the speakers and see if that amp is still distressed. If it looks clean and happy start adding speakers until it returns (or not).
Jul 03, 2011 | NAD M25 Amplifier
I've bought my NAD C326BEE amplifier almost two years ago, and i got promised a hell of a good quality and that it would last for YEARS. But ever since i bought the damn amplifier, it has been shutting off...
I'm also a Nad fan. I find this pretty odd that you should loose two in such a short space of time. The cutting out is due to the "protection circuit". I would be inclined to get your speakers checked out as if they are faulty or not "matched" to the amp, it will trigger the amp to "protect itself" and shut off.
Jan 07, 2011 | NAD C326BEE Amplifier
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Jan 04, 2010 | NAD C521 CD Player
NAD C326BEE Amplifier Logo
969 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
