Question about Creative Labs SBS 330 Computer Speakers
Humming noise from speakers
I am getting humming noise from my computer speakers whenever i plug the power cord. I tried disconnecting the jack from the CPU and also switching off the speakers. But nothing worked. When i switch off the power supply the noise stops. Can anyone please suggest me a way to solve this problem?
Thanks
  • Creative Labs Master
  • 5,568 Answers
You've done your homework on eliminating potential external sources so one of the few things left is a failed filter capacitor in the power supply of the unit.
'Hum' is one of the most common signs of this.
If a capacitor fails catastrophically, there are normally visible signs of it.
If you are adventurous, you can invade the subwoofer box where the supply and amplifier are probably situated and look at cylindrical parts in the area closest to the AC input.
The supply will be in whatever case to which the power cord is attached and the bigger box is the most likely candidate.
Capacitors of this kind can be in size from a 1/4 of an inch to 1 1/2" in diameter, have a plastic sleeve around them that is normally open at the top where the aluminum of the case is visible and they are mostly installed vertically in the board.
These often (but not always) have 3 scored lines radiating from the center.
Check around each of these for any signs of crusty deposits and on their tops, look for signs that the top has bulged.
If you find any looking like that, they are probably defective.
There are values on the sleeve that will be in 'uF' and voltages expressed in DC; i.e. one that bears 47uF/16VDC needs to be replaced with that same value.
If you make it that far, you will need only few tools but a decent soldering iron to remove the failed part and pay attention (marking is best) where the + and - leads go since they will fail and make a mess if improperly polarized.
If you do not see any with the signs of failure described, the only recourse is to find a tech with a capacitance meter necessary to find the failed part(s).
Since the cost of repair by any shop would exceed the replacement cost of a new set, you may end up contributing to a landfill.
Posted on Aug 16, 2008
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
My powered sub is humming
Does the humming go away if the cable is plugged in but you wiggle it? May be a bad connection on the input jack.
Mar 22, 2013 | Klipsch Audio Players & Recorders
When I turn amp on there is a loud humming that does not stop.
try plugging into a different socket if that doesnt solve problem you may need to replace cord. sounds like a loose neutral in socket though.
Dec 01, 2012 | Fender Frontman 212R 100W 2x12 Guitar...
When i turn on the power for my speakers it hums like crazy
do they hum when you unplug the audio jack from the PC?
If they stop humming when disconnected the problem will be down to a bad earth connection on the motherboard, or a failing power supply (rectifier circuit)
Humming is normally a result of voltage potential and the 50hz frequency in the mains.
Hope this helps
Apr 22, 2012 | Altec Lansing VS2621 Speakers
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
I HAVE A Z-2300 NO SOUND
Is it plugged in with a 3.5 millimeter jack? If it is, pull it out of the computer and press you thumb on the tip, if no humming noise comes out, your speakers are probably blown.
However, if a humming noise does come out. Please check to make sure the volume on the computer is turned up/unmuted, the software's volume is turned up/unmuted, your sound card driver is installed (Right-Click "My Computer" -> left click on properties -> Click on the Hardware tab -> click on "Device Manager" -> Click the "+" next to "Sound, video and game controllers" and make sure there is no Red "X"'s or yellow "!"'s.
If you do get a hum, and you do have everything set up right in Windows, try a different pair of speakers or head phones. Your sound card might be fried.
Also, make sure you're plugging the speakers into the correct port on the computer (It's usually a washed out green port"
Mar 01, 2010 | Logitech Audio Players & Recorders
Humming Noise from satellite speakers
noise can be generated since dust in the jack connector of your PC, bad sound card or belive or not, the socket. try to unplug another devices and leave alone the x240... compare.
Apr 02, 2009 | Logitech X-240 Computer Speakers
Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Sep 04, 2007 | Audio Players & Recorders
Open Questions:
See all Creative Labs SBS 330 Computer Speakers Questions
Creative Labs SBS 330 Computer Speakers Logo
286 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
