Question about JVC Car Audio & Video
My jvc cd reciever model #kdr616 has for some reason decided to constantly blow the 15amp fuse on back of the unit. can you point me in thev right direction to rectify this problem. thanks
  • JVC Master
  • 2,098 Answers
Hi dionsparky,
If your replacement fuse has an exact current ratings and yet immediately blew after an installation, this is an indication of shorted parts in the supply voltage line. Most likely it was caused by shorted output IC which is mounted in the heatsink. If your handy with electronics and have some necessary tools, pull-out this IC by deslodering it to the board and try the unit without this parts. If the fuse does not blew and finally the unit power up, you must replaced this IC and your unit will back to normal again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
A 2004 Dodge Stratus blew the door lock fuse (15amp). Replaced it with another 15amp and it blew again. Replaced it with a 25amp and it works fine. What should be replaced so the 15amp will work again
Why would you replace a fuse with a larger one ?
Trying to burn the car down ?
Need to test the door lock solenoid inside the door,
to see if that is the reason the fuse blows
If your putting in larger fuses, you surely should not
be working on vehicles or anything with electrical current
Oct 22, 2014 | Cars & Trucks
Why does a fuse blow in my JVC receiver Model AX-S331?
usually a crossed speaker wire, or overdriving the amp will cause a fuse to blow
Mar 21, 2013 | JVC Audio Players & Recorders
I hooked my head unit up and it wont power on yet if i put a cd in it will come on recieve the cd and turn back off also the disp turns it on for a second. what is this?
you need to make sure 3 wire are connet the right way one is constant power,2 ground,3 acc. ingnition also there is 1 more wire you need to connect is the remote blue or blue/light blue.
Dec 27, 2010 | JVC KD-G801 CD Player
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
My JVC THM303 will not work at all. took it apart to see if there was a blown fuse and the fuse is blown but do not know where to get on. The fuse says 51MS on one end and 125V1.6A on other
You need a 1.6 amp gma fuse, be sure not to get a slow-blow fuse.
Fuses blow for a reason (a short circuit). Not very often does it only need a fuse. I suggest trying only once if it blows again right away, take it in for service.
Nov 16, 2009 | JVC TH-M303 System
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Jan 12, 2009 | JVC KD-S570 CD Player
Car CD player
bose provided the speakers, now problems relating to cd play from that point of view.
i had similar problem in my volvo , and decided to take the stereo out to find out why it would eject. i dscovered my kids shoved coins into the cd player slot.......... even though the disk itself was also not good......
if for some reason you decide to remove cdplayer element of stereo from car ( as car may be too long out of warranty )or you fell cool about doing this, just make sure you dont disconnect the climate control or the on board unit with central locking switches, or you will still have to bring your car back to the main dealer to get the air bag and locking systems reset. even removing the fuses from the fuse board wnt help here if you decide to proceed with DIY CD player repair as removing the wrong fuses or combinations of fuses (FOR YOUR MAKE AND MODEL OF CAR) will result in the same situation on re installation.
good luck.
Jan 17, 2008 | Bose 3 2 1 GSX System
Blowin fuses
it is always best to have fuse on battery lead but as long as the leads are definately going through the fuse panel then you should have no problem but if you have the fuse and it blows then their is deffinately something wrong.
The fuse on the battert leads is a backup as long as the wires are running through main fuse panel the reason for extra fuse is because the main fuse works other things running off it not just the one for radio so the fuse on the battery lead is their so that if something wrong with the unti then that fuse blows and only that 1 unit wont work but if main fuse blows other things might not work so its always best to have inline fuse so that only the 1 unit stops working incase of problem.
so its not vital you have one but it usefull so that you know where the problem is coming from and saves time tracking down fault
Jan 11, 2008 | Panasonic CQ-DFX972U CD Player
No power
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW glass fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved.
The repair took minutes - 3 screws on the back and two screws on each side. Lift the cover from the back (it is slip-hinged on the front) and replace the ceramic fuse. It slips out with a little help and the new one snaps in place.
Jul 21, 2007 | JVC TH-C30 System
Car Audio & Video Logo
57 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
