Question about Coleman 2 Burner Dual Fuel 424-700G Grill
Hi my coleman 533 has orange flame not blue it has good pressure i have taken jet of end of generator and cleaned it
  • Coleman Master
  • 6,674 Answers
Orange or yellow flame is usually an indication of too much fuel, or not enough air mixture. Make sure all areas where burners would receive air from, are cleaned of spider webs, debris etc., and be sure when set up, nothing is close to it that would block that air flow from entering.
Posted on Jun 04, 2011
I have a Coleman Presidential III, pilot light lights then in 10-15 minutes the heater cycles off. How do I fix it?
Check pilot is strong and blue if not clean it . Check thermocouple is clean and not brunt out . check flame sensor is clean and in position . check air filter is clean . Check pressure switch .
Nov 11, 2016 | Coleman Heating & Cooling
ONE of my burners on the coleman grill has low flames, the other burner is normal. what do I do?
The low jet probably has a partially blocked jet. It isn't unusual for paraffin or petrol fuelled burners to become blocked and the jets have to be cleaned regularly with a jet cleaner or pricker - a thin hard steel wire clamped in a pressed steel holder. Modern or premium products often have an internal jet cleaning mechanism built in.
It is rare for propane or butane powered appliances to suffer blocked jets but it does happen sometimes. If the jet is accessible it can usually be cleaned with a pricker of the right size but if it isn't accessible or the pricker provides only a temporary cure, the appliance will need partially dismantling and the jet (or nipple) removed for cleaning.
Sep 21, 2016 | Coleman Roadtrip Grill LXE 9949-750
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Orange flame
A orange flame means that not enough air is mixing with the gas to produce a nice clean burning blue flame. Try cleaning out any deposits of grease or anything else that could be blocking the air pathway to the flame.
Mar 23, 2014 | Frymaster Dean FPEL4 Deep Fryer
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any...
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Sep 16, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Coleman generator will start but won't continue to run
Remove Carb and clean and soak then blow out the jets. This is a common problem as they tend to set up with old fuel in them and when you want to start them the Jets are plugged. I bet it does run with the choke on?
Clean the Carb.
R/
David
Jan 21, 2010 | Coleman Powermate Powermate 5000W...
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Coleman 425 2-burner white gas stove pops out flame on low heat
There is water in your fuel. Drain the tank and flush it out with denatured alcohol. Refill with fresh fuel.
Jun 21, 2009 | Coleman Sport & Outdoor - Others
Why is my stove causing a thick coat of soot to buildup on my pots?
you have to adjust the air intake holes at the valves. this will give you a blue flame.
Aug 16, 2008 | Coleman Propane Grill Stove 9921-700
Coleman 2 Burner Dual Fuel 424-700G Grill Logo
361 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
