Question about Topeak Twister Digital Floor Pump
Hello, i need manual for topeak twister digital pump
Topeak mini G dual pump
You are most likely using the pump set up to work with a Schrader valve when you should be using it with the internals set up to work with a Presta valve. This video will help you identify the valve type and explain how to change the internals of the pump: http://www.topeak.com/pages/368/news/detail/832
This video will explain how to change a flat:http://www.topeak.com/pages/368/news/detail/830
I hope this helps, Eddie O - Topeak Inc
Nov 15, 2012 | Topeak Mini Master Blaster
Topeak comp 150 directions
If anyone still needs a Topeak Comp 150 manual, it's still available for download from here:
http://www.m.topeak.com/mediafiles/assets/177
They haven't made it easy though.
Apr 23, 2012 | Topeak Cycling
Just trying to figure out how to install the topeak aero wedge pack
Search engine "install the topeak aero wedge pack" takes you right to it - immediately.
http://www.topeak.com/products/Bags/AeroWedgePack_large_Quick
The manual is there to download.
Fixya experts need not be in the loop. You could have had your answer, um, 6 hours ago.
Aug 03, 2011 | Topeak Cycling
User Manual l for topeak 140
Go under service, downloads, yada yada
Mar 10, 2011 | Topeak Comp 140
Pump will not draw air back in after a pump.topeak master blaster mini dx
I think I know your problem: The valve at the bottom of the pump which controls the in-out flow of air can get clogged largely with residue from the gasget as it wears. My suggestion is to take the pump back to the shop where you purchased it as Topeak usually honors its lifetime warantee.
Jan 18, 2011 | Topeak Road Morph Pump with Gauge
User manual for topeak comp 130
Hello i note that you have a pdf of the Topeak Comp 130 I would appreciate a copy. Mt email is djf@way.eldercare.net.au
thank you and regards David
Aug 31, 2009 | Cycling
I need setup instructions for my speedometer
Download the manual from Topeak's website:
http://www.topeak.com/Service_and_Tech/Downloads
Jan 07, 2009 | Topeak Panoram V12 Mini 12 Function Cycle...
Topeak Twister Digital Floor Pump Logo
69 people viewed this question
Top Topeak Sport & Outdoor - Others Experts
Are you a Topeak Sport and Outdoor - Other Expert? Answer questions, earn points and help others
