Question about Garden
Max ripping on the dewalt dw743 flipover saw table
  • 313 Answers
SOURCE: tile saw stopped working
check the motor might have a reset botton or check the capacitor
Posted on Jun 05, 2008
  • 8 Answers
SOURCE: Dewalt Table Saw
I don't know about Cleveland, but a while ago I replaced the bearing on my Sears Craftsman saw, and it wasn't a hard fix. I would expect any competent repair shop could do the repair easily. If you can get the arbor off and take it to the shop, that would be ideal. It only takes loosening a few bolts to get it off. I first removed the cast iron top from the sheet metal base so I could turn it over, but it can be done from the bottom, too. Just be prepared to eat some sawdust. The most specialized thing the shop would need is a bearing press to get the bearing in and out of its seat, and many shops would have these; they aren't very expensive. Maybe a good machine shop which does small jobs could do it for a small fee. A good place to find these is at your local auto parts store, such as NAPA or O'Riellys (here in MIssouri, anyway, but you get the idea). Your auto repair shop probably knows one or two they use for 'turning' brake drums, etc. BTY, I didn't have a bearing press and I did the job with carefully tapping the bearing back on with a sleeve made from a piece of scrap pipe. Tauton Press makes a great DVD on tuning up your saw after this fix, as you want to make sure
it is square with the table in two dimensions - parallel to the miter saw slots and perpendicular to the top. Good luck.
dcm
Posted on Oct 01, 2008
stug_57u
  • 99 Answers
SOURCE: delta table saw
The reset button is normally a thermal overload, using a bio-metallic strip to break the circuit. If it is old or has popped a few times it might have 'weakened' abit. Try replacing the thermal/reset button. If it still happens then something might be overheating and causing the problem.
Posted on Nov 01, 2008
agent91
  • 2100 Answers
SOURCE: how do you align the blade to the mitre slot on a
How did the blade get out of whack? Take the blade all the way up, put a straight edge against the blade, measure to the miter slot front and rear, if it is not the same, you will have to lightly loosen the carriage underneath and bump the thing over one way or the other with a lead hammer. Get it straight, then torque it back up. You should be all set. You can set your fence to the miter slots the same way. lock it down and check it, if it isn't right, adjust the fence, all fence adjust , from the cheapest to the best. Hope this helps.
Posted on Mar 29, 2010
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
Mastercraft 2 in 1 flip over saw only works on one side
You have a safety lock as the table turns to table saw with an open blade.if you don't hear the click or one of the wires on the locking mechanism have come loose it will not function. Used to have one but I wore the motor out - best portable saw I have owned and I own a lot of high end saws.if anyone has a flip saw for sale let me know - pipeline@nucleus.com.
May 31, 2013 | Saws
How do i square the table to the fence on a dewalt table saw?
Normally we adjust the rip fence so that it toes out 0.10 mm over the lenghth of the rip fence. Some models have to have the trunion shimmed or the table removed/adjusted to achieve this. The toe out ensures no binding but doesn't effect the measuring. Note. adjusting the trunion is a large job.
Feb 11, 2012 | Dewalt DW744X 10" Portable Table Saw
How do you adjust the rip fence on the Dewalt 744 type 1 table saw
there are 2 bolts on the backside that you need to loosen and move the fence to the blade to align it properly, after aligning tighten the bolts and I always recheck to ensure that it didn't move, there are instructions in the owners manual and if you don't have one you can go to dewaltservicenet.com and download one for the tool. Let me know if you need more assistance
Sep 27, 2011 | Dewalt DW744S 10" Portable Table Saw with...
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Jul 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
New saw purchace
Two main problems will be space (hence your plan for a rolling cabinet) and rust. Get a contractor style saw (which has the motor under the table instead of hanging off the back) and has an aluminum table (instead of cast iron). Unless you aren't going to put cars in your garage anymore, I wouldn't worry about being able to cut sheet goods on the table saw. There are simple solutions using saw horses, clamping a guide board on the sheet and using a circular saw that are much more flexible and surprisingly accurate. This takes up a lot less space and is easier to control than doing this on a table saw.
Jan 11, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Dewalt dw744 motor runs slow and smokes, what parts need replacing?
probably whole motor, if the bearings started to seize up it could have caused the armature/field to burn or if you overloaded the tool the same thing would happen. Does the tool have a burnt electrical smell, if so the motor is burnt and the cost of parts might outweigh getting repaired, You can go to Dewaltservicenet.com and find out the prices and also you might want to call a Dewalt Factory Service Center and ask them about the MAX repair rate on this tool and they will fix everything for that price, no matter what.
Oct 12, 2009 | Dewalt DW744X 10" Portable Table Saw
Dewalt 10" table saw, when ripping jambs @ back of guide?
Without knowing the full problem, (theheader is cut off) I would ask are you using the fence to help you rip? and when does the board jamb? If it jambs toward the back of the saw the guide might not be square with the blade. I would unplug it and put something that you know is square on the front edge of the blade away from the teeth and adjust the fence so that it is just snub then lock down the table and move the square to the back of saw, it should move with no resistance. If it does then the fence is out. What you would need to do if this is the case is align the fence to the blade, on the back of the saw are 2 10MM bolts that you need to loosen put your square at the front again and lock down the handle with that done move the square to the back and tap the rail on the back side to move tighter or looser and then lock down the bolts. What I do is move the fence away and then back and start all over again to make sure nothing shifted. It sounds more involved than it is. Let me know if this cures your problem
Jan 12, 2009 | Dewalt DW746X 10" woodworker's table saw...
Blade Height
Basic saw safety dictates that the blade should barely clear the thickness of the material being sawed. This has saved my fingers more than once, Also, make sure you use a push stick for thin rips. They are a lot easier to replace than fingers, and are easily made from scrap stuff. As for the blade diameter, you want to use a 10" blade, but on occasion a smaller blade can be used, just be sure the arbor doesn't rub against the bottom of the table. Dado blades for 10" saws are usually only about 8" in diameter.
Aug 27, 2008 | Dewalt DW744S 10" Portable Table Saw with...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
