Question about Cell Phones
Samsung GT-I5503 i had an error message "emergency dload mode (ARM9 mode)" for a ~20mn, the mobile switched off automatically and i switched it on again, it works. what does this error message mean.
asber
  • 291 Answers
SOURCE: SamsungGT-S5233-A:How do i block message from a particular mobile
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Posted on Mar 03, 2010
Testimonial: "Very much relieved ... thank you"
Geekman
  • 32281 Answers
SOURCE: Have few problems with Samsung Galaxy 5 GT-
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on Nov 24, 2010
SOURCE: Hello, I cannot use USSD command
Dear friend
I ahve same problem for my Galaxy 5 , I found a progrmam for this problem , Vodafone USSD commands. ... , which you can found it in Android Market .
Thanks
Sirous
Posted on Dec 01, 2010
  • 782 Answers
SOURCE: Samsung Galaxy 5 GT-I5503 problem in getting 3G
sir please call to the bsnl simcard customer care and say the cellphone model number.and the phonenumber then they will send the gprs settings to your cellphone save the settings and switch off your cellphone and again switch on.then connect the data cable from phone to the computer for connecting the internet...........
Posted on Jan 05, 2011
  • 13 Answers
SOURCE: my mobile is samsung gt
check on/off switch or get full flashing of the phone
Posted on Mar 06, 2011
Allows emergency calls only
Is subscription paid up to date?
Check that your Sim Card is in place?
Get a hold of your provider.
Another person suggests:You might be set on the wrong network type. In my area O2 doesn't have a 3G (CDMA) mask so my galaxy S3 automatically switches to a network that does for "Emergency Calls" - which means your on another providers network just you can only make emergency calls.
What I have to do is force my galaxy S3 into GSM (2G) networks. So then it will connect to O2 mask and I can text/phone as normal.
Go to Settings, More Settings, Mobile Networks > Network Mode. Click GSM. See if that helps. If it does then go to "GSM/WCDMA Auto"
If not then you may not have any of your providers network masks nearby (go to another location to check this). Or the provider is having problems (check their website status page). I don't think a factory settings would help
Galaxy S3 stuck in emergency calls only mode techsupport
May 12, 2015 | Samsung Cell Phones
Phone is showing emergency calls only
Hi, you can unlock "Network lock control key" screen with the following service for your phone model: http://www.fastgsm.com/en/samsung/samsung/gt-i5503/unlock-code
Nov 16, 2012 | Samsung GT 15503 Cellular Phone
I have samsung GT I5503, I WANT 3G SETTINGS FOR AIRCEL AND BSNL. WOULD YOU PLEASE GUIDE ME. ADVANCE THANKS.
Aircel Pocket Internet Manual Settings
Go to Menu > Tools > Settings [ if settings not here then check other folders ]
then go to Connection > Access Points > Create New Access Point > Default Settings
Just Put Access Point Name [APN] as aircelgprs
leave everything as it is...
go to web browser make this connection ur default connection
switch off ur mobile for 2 minutes then on & connect
Mar 24, 2011 | Samsung Cell Phones
My Phone S3650 shows network error whenever i dial a number or shows message sending failed when i send a message where as it is displaying full signals.i recently got it from saudi arab to another...
Go to menu -> settings -> network settings. Go to select network and set to 'automatic'. Then go to network mode and set to 'automatic'. If this doesnt work you may have to contact your mobile operator.
Mar 10, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Hi i m TUSHAR ..i have samsung GT5 I5503 mobile. i forgot my unlock pattern and also my username and password are also shown invalid. PLEASE tell me hw to unlock
Contact your cellular service provider and request Tech Support assistance. They will provide you with a Master Unlock Code for your phone. After entering it, you can then change the PIN to one you'll remember.
We cannot provide Security codes on FixYa as we have no way to verify the ownership of your phone.
If all else fails, visit this website: http://www.onlinegsmunlock.com/unlock-your-phone/rs7wp2/
Jan 26, 2011 | Cell Phones
IS SAMSUNG KIES SOFTWARE FOR MY SAMSUNG "GALAXY 5 i.e. GT I5503 COMPATIBLE FOR RUNNING INTERNET ON PC THROUGH BLUTOOTH.
Hi mkjagoar,
According to the Samsung Galaxy 5 i5503 specs it is Bluetooth compatible.
Check out the specs here:  http://www.qcellphone.com/samsung-galaxy-5-i5503-use-600-mhz-processor.html
but I do not see anything that says Samsung KIES supports Bluetooth.  Look at this link and you will find a compatibility link at the bottom of the page.
http://pages.samsung.com/ca/kies/English/
Hope this helps
Dec 26, 2010 | Samsung Computers & Internet
HAVE PROBLEM CONNECTING MY SAMSUNG GT-I5503 WITH WIFI INTERNET. IN THE SETTINGS , IT SAYS UNSUCESSFUL. IT IS AUTOMATICALLY DISCONNECTED
im using samsun galaxy i5503. when i turn on wifi its says enable to wifi. so i off the phone and on again.than only can use.it is always happeenning too bad. and the other one is when im using the wifi suddenly power was off i try to press the power key batton but useless so i took out the battery n power on again than i can use wifi.its always happen. too bad.pls tell me how to solve the wifi problems??????
Dec 21, 2010 | Samsung Cell Phones
Samsung flight phone issues will not let me make or receive calls. Say emergency calls only.
using flight mode you cannot make calls
you have to switch it to normal mode
1. Flight mode [Support > Glossary]
In this mode (also known as offline mode ) you are able to use functions on the mobile phone (calendar, calculator etc.) even though the phone is not connected to a mobile network. You cannot make calls in flight mode .
Mar 30, 2010 | Cell Phones
Samsung mobile phone > GT-C3053 (GT-C3053) user
samsung GT-C3053 switch on and it shows greetiing msg again and again. it did not go next step
Sep 19, 2009 | Cell Phones
Cell Phones Logo
288 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
