Question about Whirlpool AKZ159IX Oven
The grill works but the fan over does not. What do I need to do to fix it?
  • 24 Answers
Hi Your clock timer is probably on automatic try resetting the clock If it is on auto you will have a auto light up somewhere in the display
Posted on May 29, 2011
How do I fix a continuously running upper oven fan
Without knowing the make and model, this is a guess, the fans usually run for some time after switch off, to allow cooling I am guessing this carries on until you isolate the mains. If so you have a thermostat problem. It would be easier to de-fine if there were more information.
Regards
John
Oct 31, 2014 | Ovens
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Thanks.
Jul 15, 2009 | DeLonghi Ovens
Not heating in fan forced mode
Possibly your fan element has blown. Try and take the cover off that coves the fan inside the oven itself and use a torch to look at the element to see if it looks out of shape etc.
Jun 15, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Whirlpool AKZ159IX Oven Logo
61 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
