I am unable to open BIOS. When system booting, message occurs Key board failure. because of that no keyboard keys works for going in BIOS. while key board works fine after loading OS(WindowsXP).
    Sergeant:
  • 207 Answers
Update your BIOS while on windows using a windows utility of your motherboard manufacturer. It could be a firmware problem.
Posted on May 27, 2011
  • 336 Answers
YOUR KEYBOARD USB TYPE OR PS2 TYPE? COMPATIBLE TO BIOS SETTING PS2 TYPE KEYBOARD ALSO TRY TO CLEANING VACUUM YOUR MOTHERBOARD INSIDE CPU.
My hp desktop computer was working well but after a lightning, it is able to boot with no usb port responding and it does not have a ps2 mouse or keyboard connector. What should i do?
pls clear cmos jumper first. after power on and go to bios by press the key board key. if worked, pls check the O/S setup or recovery setup . pls select select system restore and press restore previous date.
if not working usb key board and install PCI or PCI X usb adapter and plug to key board and mouse to it and go to bios and disable on board usb controller.
go to O/S and check
Jan 04, 2017 | HP Computers & Internet
G31-M7 TE keyboard problems
you have to run the DRIVERS CD FIRST.
Apr 11, 2013 | Biostar G31-M7 TE Motherboard
LG Keybo2 Will not stay turned off, have removed battery to try and reset but when I put battery in, just reboots, hold down the OFF button, turns off but then immediatly reboots and turns back on
F keys don't work on reboot. Work on Power on boot.
When powering on the F2 key will get me to Bios Setup, F8 key will get me to Safe Mode, and F12 key will let me change Boot Device. Everything is normal when up on XP operating system. If I reboot, None of the mentioned function keys work. Instead I get a message of a "Keyboard Failure", but system will come up OK. But, on the reboot, I want to use one of those function keys.
I have a DELL 2400 Dimension running Windows Home XP. I am using a Logitech EX-110 (Combo keyboard & mouse)
This seems very similar to another write up on this site.
Any ideas? Don't tell me to toggle the keyboard. I tried it with no positive results
Dec 02, 2012 | LG 10X DVD IDE 452000078
Unable to restore
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Nov 26, 2011 | ASUS Eee PC 1001P Netbook
Shift key not working
keep press ing the shift button and press the required key
Nov 04, 2011 | Computers & Internet
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
Keyboard keys not working when you hit them.
Open a notepad using mouse and then check if u can type in notepad.
Shut down and reboot the system and boot in bios by hitting F2 or F10 or Delete key on keyboard. If u are able to boot in bios ,reset bios.If unable then disconnect keyboard and try different port to connect.If issue persist replaced keyboard.
Aug 17, 2009 | HP Computers & Internet
Suddenly getting boot failure message averatec 3200
this could be do to a bad connection to the boot device such as the harddrive.
I would try to boot from the cd rom using the OS disk.
Aug 07, 2009 | Averatec Laptop Keyboard for 3200 Series
Turn your computer off.
Temporarily replace your keyboard/mouse with "generic" units.
Turn your computer on.
Check that the F-keys work.
Restart.
Now, do the F-keys work correctly?
Or, do you still get "keyboard failure"?
Jul 22, 2009 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
