Error in network connection - Computers & Internet
  • 122 Answers
Can you elaborate on the issue and repost
thanks
rene
Posted on May 27, 2011
Error 1114
Hello Bruce,
Since you are here you have internet connection. Best solutions for network errors and problems is do a web search for the error. here is one solution for the problem.
http://answers.microsoft.com/en-us/windows/forum/windows_vista-networking/error-1114-dynamic-link-library-dll-intialization/f6245128-52f8-4fb7-a66b-9928c483cf8a
Nov 01, 2014 | Computers & Internet
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
What is sony error code 1106. On selecting the internet this error code is displayed. I have done a hard reset of the tv by removing power but this didn't work
Solution proposed by Soufane (member of the Fixya community) :
  • Rank: Wiz
  • Rating: 99.31%, 51 votes
  • Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection:
    1. Check the Network Connection.
      1. Using the supplied remote, press the Home or Menu button.
      2. Select Network Setup .
      3. Select View Network Status .
      4. Select Check Connection .
      If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection.
      Follow these steps, if the error continues to appear:
    2. Unplug the TV and wait 60 seconds.
    3. Power on and off all of the networking equipment, including the modem and router.
    4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer.
    5. If the issue continues, wait and try viewing the content later.
    Jun 20, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
    900 service rip software
    The 900 error usually indicates a software or communications problem. If the 900 error occurs only when the printer is receiving information from a network or computer, you should contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer.
    To check the base printer
    Turn off the printer and disconnect every cable, except for the power cord.
    Turn on the printer and see if the error returns.
    If the error does not return, try to print a test page from the Test Menu.
    If the test page prints correctly, the printer
    May 05, 2011 | Lexmark Optra T610 Laser Printer
    Sony PS3 ERROR CODE 80710092?
    80028EA8 - Seems to mean unable to authorize isp account details
    here are some of the ps3 error code that might help you in the future..
    Complete PS3 Error Codes:
    0710102 - DNS Error; No DSN server available.
    8013030 - System Error due to failed update download
    80010001 - Major Error , Game ability stopped
    80010006 - An error occurred during the start operation (corrupted folding install)
    80010007 - An error occurred during the start operation (during disc swap tests)
    8001000B - it happens when trying to establish wireless connection
    80010017 - Can't start BlueRay Game
    8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown
    8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
    8001050F - Hardware failure. Cannot update firmware or connect to internet.
    80010510 - Will not play games installed on the hard drive
    80010514 - Possibly reading blu-ray disc problem
    80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
    80023101 - Unknown
    80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server
    80028EA5 - User cannot connect to PS3 network
    80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.
    80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,
    80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again
    80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
    80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
    80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
    80029023 - Exchanging Key Information exchange has timed out
    80029024 - "The attempt to obtain an IP address has timed out".
    80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)
    80029501 - connection
    80029509 - When the PSN network is down for maintenance.
    80029513 - This content cannot be accessed on your account (80029513)
    80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)
    80029564 - Downloaded game will not install
    80029751 - warhawk wont start but eveything else seems ok
    80029945 - Can't playback burn BD movie
    80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )
    80029C68 - Corrupt data usually on external device
    8002A10B. It shows up when I try to view my friends trophies, profile etc.
    8002A10D - Unable to Add friend in XMB
    8002A4A6 - Cannot load game to play online
    8002A515 - Error Signing in
    8002A524 - connection
    8002A548 - Unable to remain logged in - either to game or server
    8002A705 - Unable to connect to server/host. Check router port configuration.
    8002AD23 - Unknown
    8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.
    8002B241 - DVI has no audio.
    8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
    8002F994 - Too many people downloading the update (download it later on)
    8002F997 - Can not update XMB firmware
    80030001 - Deleting messages from inbox
    8003041F - An error occurred during the copy operation (using media server)
    80030517 - It seems to happen when you copy large media files.
    8003051E - Game will not save
    80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)
    80031150 - "Setting information is corrupted.Press the x button to repair and restore default"
    80031601 - Error Creating Account
    8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none
    8013013D - connection
    8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
    80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.
    8013030F - Access Point not detected
    8041040F - Communication with the server failed. A dsn error has occured.
    80410418 - DNS Error
    80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
    80710016 - Playstation Network is down.
    80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"
    80710101 - Connection error
    80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
    807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error
    8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection
    80710541 - The connection to the server timed out.
    80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
    80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured
    80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
    80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode
    81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
    Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
    Error code 80710b23
    Hello Mr =)
    80710B23 PS3 Network is Down or PS3 Network is too busy to respond
    Jun 05, 2010 | Sony Playstation 3 (PS3) Console
    Can't make a wireless connection.
    what's the error? if your getting the error Connected with limited connectivity try checking your network key in the router and the wireless settings on your computer if they are correct or just removed your security key, if your getting an error no networks in range or no network available check the router settings if the wireless signal is turned on the router, if you get an error windows could not connect to wireless networks try uninstalling and reinstalling the wireless card driver on your system and set the the router to defaults then try connecting with out changing any settings in the router to see if it will connect, if it connects, then there was/were settings in the router and possibly in the wireless settings in your laptop that was causing the computer and the router to have communication issues, also check for possible applications such as network magic that could cause a wireless signal to degrade or not allow connections at all if such application exists on your system uninstall it Microsoft or windows has its own wireless configuration software built into handle wireless connections in XP it is wireless zero configuration in vista and in win7 WLAN which can be set in network and sharing connection in the control panel window.....
    Jun 03, 2010 | Intel Computers & Internet
    How to fix message error 900.00 service RIP software on Lexmark c 530 dn
    Does the error pop up when the printer is booting up, receiving information via network, connected via usb, or connected via parallel cable? It could be two problem. If it would post during printing, then it could be cause by a software or network problem. Test the printer in a standalone mode without any usb or network connection, if the error would post upon power up and without any network connection or usb connection then its a hardware problem. If it's a hardware problem, it would require a service call.
    May 10, 2010 | Lexmark C530dn Laser Printer
    Computers & Internet Logo
    22 people viewed this question
    David Payne
    David Payne
