Question about 2wire (1000-000057-000) Modem
Setting up ip and dns address again
Thanks so much for your comme ithana, now just another question following your advice. Could you explain how to go about doing this and also how do you know which dns and ip address to put in??? would doing a ipconfig/release and renew work in this situation???
  • 185 Answers
Open the properties in network wizard select tabs required for ip address ,dns address ,etc
Posted on Aug 16, 2008
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Tip
How to change your DNS (Domain Name Server) on your Windows computer. Faster...
Hi Thanks for looking.
Your ISP (Internet Service Provider) provide you with Domain Name Server which translates website names to language that computer can understand which is an IP address of the website. Faster the response from DNS the faster your website will load.
In this tip I will explain how to change your Domain Name Server (DNS) in order to speed up your web browsing.
Go to
Start--->Control Panel--->Network Connections
Please note that you may need to switch to "Classic view of Control Panel in order to see default view.
Right click on network connection that you are currently using and choose "Properties"From the list in box choose "Internet Protocol (TCP/IP) and click "Properties" below. You will be shown a window with two tabs and in General Tab you will have options to change your IP address (we don't want to touch this)and option to set DNS manually.
Click on " Use the following DNS address"Now you can change your DNS to whatever you like. I recommend "Open DNS" which is faster then most of default DNS's.
Ok to change your DNS to "Open DNS you need to type 208.67.222.222 in preferred DNS box and 208.67.220.220 in Alternate DNS box.Click OK and then OK again.
Bravo! You just changed your DNS.
slow internet, website will not load, speed up my internet, how to speed up my internet
on May 07, 2010 | Computers & Internet
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
My ip adress is gone of laptop how do i fix it
Normally IP Address is assigned by your router which then also provides gateway and dns settings. On the IP address screen, select Obtain automatically for both IP and DNS.
If this does not solve your problem, please explain fully what the problem is.
May 12, 2011 | ip-adress.com
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    I had to assign my router a new IP address and that made the wireless computer loose its connection, how do i reassign the wireless computer to the new IP address?
    That is easy. You have to change the Default Gateway. Make sure you are running DHCP in the Router as well. Otherwise you may have to change the IP Address of the Computer to suite the New IP Address and its Subnet.
    1. You have to go to "Network Connections" in the Control panel.
    2. Go to the Wireless Adapter Section and Choose the Local Connection.
    3. Right Click on Properties and the Double Click on Internet Protocol (TCP/IP).
    4. If you are using a "Static IP Address", Please change the IP Address of your Machine to suite the IP Address and Change the Default Gateway to the New Address (And then the DNS Server Address as well, if you are running DNS from your Router).
    5. If you are running DHCP (You will see that the boxes are Blank and "Obtain IP Address Automatically" and "Obtain DNS Address Automatically" selected) this cannot happen. Then you have to check your Router's DNS Settings for the Internal Network. Make Suitable Changes.
    6. If you have tried this only once and if you have the DHCP running try changing only the DNS in the TCP/IP settings. It may work. Or try to Release the IP and Renewing it.
    7. Use ipconfig /release and then ipconfig / renew on a Command Prompt.
    8. If you are running DNS and DHCP Locally, then you have to change their settings to Point to the Router.
    Hope this will solve the issue. If it helped you so, please be kind enough to Rate the answer with a Testimonial.
    Feel free to contact again if the problem Persists.
    Thanks for contacting Fixya!
    Jun 12, 2010 | Linksys Wireless-G WRT54G Router
    Comm.ERR on fax 5680 OKI
    You need to check parameters for LAN and e-mail settings (IP address, Subnet mask, gateway address, SMTP-server address, DNS-server address, etc). It is also important to enter "From address" in a correct form, i.e. name @domain.xxx otherways above error will be displayed.
    Aug 28, 2009 | OKIFAX 5780 Plain Paper LED Fax
    Can't connect to my router
    Try this;
    Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
    Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
    Subnest Mask 255.255.255.0
    Default gateway 192.168.1.2
    Under it choose " Use the following DNS server address"
    Input DNS address DNS of your ISP
    Click ok
    goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
    Hope it helps.
    Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
    Wrong ip address
    Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
    Mar 28, 2008 | Computers & Internet
    2wire (1000-000057-000) Modem Logo
    230 people viewed this question
    Top 2wire Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
