Question about Hitachi 55HDS69 55 in. Plasma Television
Color Changes I need some help please. My Hitachi plasma is exactly two years old and in the last few weeks we have had problems with the color. the color changes to make everyone look green. It is happeneing more nad more for a longer period of time..... anyone know what I can do? I have changed the settings and even reset the settings but it does nothing. Does it need to be calibrated?
  • DavidCMT Jan 12, 2009
    I have a Hitachi 50" Plasma just over 1 year old with same problem - usually starts OK when turned on but after a few minutes everything turns greenish. There are no red tones. I have tried all adjustments including reset to Manufacturer's original settings. Nothing helps.
    If anyone has a solution, please let me know.
  • 29 Answers
Hi.
You need change the LOGIC PWB.
Bye.
Posted on Dec 30, 2008
My Hitachi 60VG825 projection TV is 3 years old. For the past several months the screen has been turning blue around the outer edges & this past week a large yellowish green spot the size of a...
Sounds like Calibration is needed on the projection internals. Your TV uses a rear-projection system and the problem is either in the imaging LCD Unit or the light filter. I see in a previous thread you have changed the bulb. You can invest in a voltage regulator to keep the hardware in factory condition.
Also you can burn a DVD of a stuck pixel remedy video and run it on the screen with full brightness and full contrast. This is used for plasma burns and stuck pixels on conventional Flat panel TVs but can repair color issues with projection systems. This therapy is focused on the imaging unit between the projector and the main drop of your tv.
please feel free to post a more in-depth description or any changes
Nov 06, 2009 | Hitachi 60VG825 60 in. LCD Television
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Colored wavy lines on screen
This is a Logic board problem, not so easy to replace in Hitachi but well worth the repair if I had your zip code I could recommend a person or three. But the problem is a problem in the logic board and will beed replacement, Thanks for using Fixya.com
May 14, 2009 | Hitachi P42H401 42 in. Plasma HDTV
The color is screwed up
The projection TV has 3 color guns that focus to produce a single image. The 3 colors are red, green and blue. It sounds like the blue gun went out. You should be able to remove the back panel of the TV. If doing so, use caution as there is a mirror attached to the back panel. Once removed, you can confirm that the gun is not working. The fix, unfortunately is neither easy nor inexpensive. The problem could be simply a poor connection to the circuit board up to needing the replacement of a new light or perhaps a new gun. Unfortunately, there is no magic button to press and nothing you are doing wrong. This is a very nice TV and it may be worth getting an estimate to repair it. Or, perhaps this is a good excuse to go out and get a new 50" plasma! Hope this helps. If you can think of anything else I should know, please comment.
Apr 20, 2009 | Hitachi 57F500 57" Rear Projection...
The color on my hitachi 50v500 is dull and not sharp! Help
Try replacing the lamp first, If your lamp is over a year old. Next Clean the optical lens. This is kinda of involved just getting into the unit to clean.You might want to contact an authorized servicer for this.
Apr 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Hitachi 55HDS69 55 in. Plasma Television Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
