Speed of printing is very very low - Office Equipment & Supplies
  • 300 Answers
If you are talking about a fax machine, it is because the incoming document has a lot of background, or the sender needs to clean his/her fax machine.
I wish you all weren't so thrifty with words. You are not sending a telegram, see? It doesn't cost you anything to explain the problem.
Just imagine I say: "My car won't run" and don't laugh because many who come here for help say just that.
I don't get anything, not even 'thanks' most of the time. I'm only doing this for fun, see? Being a masochist can be fun.
Posted on May 27, 2011
Print not clear
from printer properties --> preferences --> device options -->
1- speed setting ( set it to low speed to have clear print) and
2- Head setting ( set darkness to upper digit to have clear print)
Jun 18, 2013 | Star Micronics TSP100 Thermal Printer
Why does it take so long to print?
Your printer is only capable of the following speeds.
Black Print Speed Up To 20 ppm Color Print Speed Up To 14 ppm
This does not take into consideration the size of the file you are sending to the printer which also takes time to spool. Always remember you get what you pay for and this is a cheap low end printer.
Aug 30, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
We have printing of pdf files in multiple,nere by 1 lakh pages within 2-3 days but now printer is printing 250-300 pages in one hour. how to increase the speed of printing ? email id ---...
Change the printer's print settings to print in draft mode.
Draft mode is a low quality, but highest speed print mode.
  1. In Windows, click on the Start button and choose Control Panel.
  2. Choose Printers and Other Hardware from the menu that opens.
  3. Choose View Installed Printers or Fax Printers.
  4. On the window that opens, look for your printer's name. Right click on the printer's icon and choose Printing Preferences.
  5. On the Print Quality tab, choose Draft or Fast (varies depending on the printer).
Mar 05, 2011 | Office Equipment & Supplies
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Jun 05, 2010 | Datamax I-4308 Thermal Label Printer
Improving print speed
no it is not..the printing speed is conditioned by the communication and the sheet ..font size..and such ...if it is appearing to be slower the fault is the communication ..but anyway look in the menu and see modes..some have a express mode for fast printing ..
Jun 01, 2010 | Kyocera Mita FS-1920 Laser Printer
D-link DIR 635. Upload speed is sometimes very low
No it is NOT, most probably a spooling problem, or may need more RAM. some jobs depending on size and type can take a long time to spool, and print, try setting print quality lower too this helps.
Mar 19, 2010 | D-Link (DI-784) Wireless Router
I have an HP Color LaserJet 2840 All-in-One. I have a Word document that has pictures on it that I was able to print 12 out of 50. Now the printer is giving me a prompt: "Low Memory; Press (check mark)...
The standard memory of this HP is 96 MB of RAM. You can add more system RAM for a maximum of 224 MB.
Sounds like the file you're trying to print is rather large, and sending 50 copies through simultaneously may well be eating up the available memory, if the unit is trying to act as a print spooler and process the entire job internally. You may want to try sending a job of 10 through and then waiting until that's processed before sending another batch through.
As an alternative, you could add the additional RAM (as above) and reduce these kinds of problems.
One thing to try is to turn the USB speed down from High Speed to Full Speed. Some of the All-in-One HP's have had problems with their USB speed matching and can cause errors in printing.
Sep 10, 2009 | Office Equipment & Supplies
No print /No error message
First, you need to make sure the ribbon and labels are loaded correctly. Follow the diagrams on the inside of the door. Once this is done, check the print speed and darkness from the front panel. If you have a high print speed and a low darkness, depending on the media you are using, it may not show the print. Try either slowing the print speed down or raising the darkness.
Aug 28, 2009 | Zebra Stripe S600 Thermal Label Printer
After About 10 tickets a white line will start showing up in the
If printing with ribbon, check to see if you have ribbon burnt onto the printhead. If so, lower the temp of the heat on print. Or you can speed up the print speed.
I have seen this happen alot when the ambient temp is low, and the printer tries to make up for the differences in temperature.
Check the hed first..
Jan 08, 2009 | Zebra 105SL Thermal Label Printer
Konica Minolta PagePro 1350W low print speed
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Jun 02, 2008 | Konica Minolta PagePro 1350W Laser Printer
53 people viewed this question
k24674
