MODE SHIFT CIRCUIT FAILED - Washing Machines
  • Washing Mach... Master
  • 2,605 Answers
Hello, welcome to FixYa. I will start by saying your post indicates only that it is a washer, however if you could post the complete model number make (brand name) and the approximate age I can speak directly about possible causes/remedies instead of generalizing. I'll need to clarify the model number before detailing much of course. I'll need to watch for your reply before moving forward. Thank you for choosing FixYa. Regards, Macmarkus :)
Posted on May 28, 2011
How do you change out 4 wheel drive switch on 2004 Yukon
Before trying to replace the switch ,are any lights flashing ? 2hi , 4lo, 4hi etc... Do you know which transfer case yours has ?
Transfer Case - BW 4482-NR4
Transfer Case - NVG 246-NP8
How many buttons ?
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel
Before you replace the switch and finding out that it isn't the problem . The switch is a low voltage input to the tansfer case shift control module (A COMPUTER ) Could have diagnostic trouble codes stored .
DTC B0790
DTC B2725
DTC C0306
DTC C0327
DTC C0329
DTC C0359
DTC C0550
Auto part stores can not read these codes .
The BW 4482 transfer case features a 3-button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria have been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly. In addition, the switch includes a VSES request button which sends a voltage signal to the transfer case shift control module. The transfer case shift control module in turn sends a request via the class 2 data bus to the ABS control module which controls the VSES system.
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel. When the ignition key is in the RUN position, the transfer case shift control module monitors the transfer case shift control switch to determine if the driver desires a new mode/range position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/range position. The lamp will continue to flash until all shifting criteria has been met and the new mode/range position has been reached, or has been engaged. Once the new mode/range position is fully active, the switch indicator lamp for the new position will remain ON constantly.
DTC B2725
Circuit Description
The range/mode switch circuit consists of 5 modes. The transfer case shift control module supplies 5 volts to the switch through the 5 volt reference circuit. The current travel through the resistor of the currently active mode. The current is then returned to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit.
When each of the modes are selected they complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch input to determine whether the Neutral, AWD, 2HI, 4HI, or 4LO mode was selected by the driver.
You may want to take this to a repair shop .
Jul 28, 2017 | Cars & Trucks
Code p2716 on 2005 corolla and location
P2716 Pressure Control Solenoid 'D' Circuit Malfunction
Possible Causes Setting Conditions
  • Shift solenoid (SLT) connector is damaged (check pins for damage, moisture)
  • Shift solenoid (SLT) control circuit is open or shorted to ground
  • Shift solenoid (SLT) has failed (electrical fault)
  • ECM has failed the solenoid is under/ behind the transmission pan
Dec 16, 2016 | Cars & Trucks
Error code p2716 in 04 sienna
Possible Causes
  • ECM has failed
Feb 27, 2016 | Cars & Trucks
I can here the tranfercase locking in but its not turning front tires at all ?
Your vehicle had option of two different 4x4 systems ,
New Venture Gear 263 Selectable Two Speed Transfer Case
The NVG 263 transfer case features a three button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached (or has been engaged). Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
The NVG 263 transfer case provides the driver with 3 manual mode/gear positions:
• 2HI - 2 Wheel Drive high range
• 4HI - 4 Wheel Drive high range
• 4LO - 4 Wheel Drive low range
OR
The NVG 236/246 transfer case features a 4 button shift control switch located on the instrument panel. When the vehicle has the ignition key in the RUN position, the transfer case shift control module starts monitoring the transfer case shift control switch to determine if the driver desires a new mode/gear position. At a single press of the transfer case shift control switch, the lamp of the new desired position will begin flashing to inform the driver that the transfer case shift control module has received the request for a new mode/gear position. The lamp will continue to flash until all shifting criteria has been met and the new mode/gear position has been reached, or has been engaged. Once the new mode/gear position is fully active, the switch indicator lamp for the new position will remain ON constantly.
If there are problems with electronic part of the systems the shift control switch light will flash warning of a problem , If no lights you have a mechanical problem in the transfer case itself .
The front axle control circuit consists of an electric motor actuator which engages and disengages the front axle. The front axle actuator motor consists of a Permanent Magnetic (PM) motor, a worm gear controlled plunger, a front axle switch and an electronic control circuit all within the actuator assembly.
The front axle actuator has four circuits connected to it, a front axle feed circuit, front axle ground circuit, front axle control circuit and a front axle switch circuit.
Whenever a shift to AUTO 4WD, 4HI, or 4LO is requested, the transfer case shift control module engages the front axle by grounding the front axle control circuit through a current limiting driver. Test Description
The numbers below refer to the step numbers on the diagnostic table.
Tests the electrical function of the front axle actuator. Helps determine between mechanical and electrical malfunctions.
Tests for proper power and ground at the front axle actuator.
Tests the operation of the front axle control circuit.
Helps determine if the transfer case shift control module is able to monitor the front axle switch.
Tests the front axle switch circuit for an open or high resistance.
Measures the voltage between the front axle feed circuit and ground.
Tests the front axle control circuit for an open or high resistance.
Inspects the front axle for a mechanical malfunction.
Tests for open in the front axle feed circuit.
Feb 14, 2016 | 2001 GMC Yukon
P0826 Nissan - Rogue 2009
P0826 Nissan - Manual Mode Switch Circuit
Possible causes: - Faulty Manual mode select switch (Built into control device, shifter)
- Faulty Manual mode position select switch (Built into control device, shifter)
- Faulty Control Device (Shifter)
- Control Device harness is open or shorted
- Control Device circuit poor electrical connection
When is the code detected? When an impossible pattern of switch signals is detected, a malfunction is detected.
Possible symptoms: - Engine Light ON (or Service Engine Soon Warning Light)
P0826 Nissan Description: Manual mode switch is installed in shift control device. The manual mode switch sends shift up and shift down switch signals to Transmission Control Module (TCM) with Control Area Network (CAN) communication.
TCM sends the switch signals to combination meter via CAN communication line. Then manual mode switch position is indicated on the shift position indicator.
P0826 Nissan Manual Mode Switch Circuit
May 31, 2015 | 2009 Nissan Rogue
I have 2004 gmc envoy xl 5.3 engine the code po753 is showing up
You are starting to have a transmission problem. I know....the Envoy runs fine....well, this code is telling you that there is a beginning of a problem with your transmission system. It could be a wire, could be a rock that was ran over flicked up under there and possible damaged something.....
Bottom line, there is a an issue developing. Suggestion? Check with AAMCO...it is free and they can give you an idea what the seriousness is.
Trouble Code: P0753 (5.3L V8 VIN P Auto)
A/T 1-2 Shift Solenoid Circuit Malfunction (4L60-E, 4L65-E)
Trouble Code Conditions:
Engine runtime over 5 seconds, system voltage at 10-18v, engine not in Fuel Cutoff mode, and the PCM detected an unexpected voltage condition on the A/T 1-2 Shift solenoid circuit.
Possible Causes:
  • 1-2 shift solenoid connector is damaged, loose or shorted
  • 1-2 shift solenoid control circuit is open or shorted to ground
  • 1-2 shift solenoid control circuit is shorted to system power
  • 1-2 shift solenoid is damaged or has failed
  • PCM has failed
Aug 25, 2014 | 2004 GMC Envoy
How do you fix a PO113 & PO123 code on a 02 Jeep Grand Charokee Larado 4.0
Trouble Code: P0113
IAT Sensor Circuit High Input
Possible Causes:
IAT Sensor signal circuit shorted to VREF (5v) IAT Sensor signal circuit is open, or the ground circuit is open
Trouble Code: P0123
TP Sensor/APPS Circuit High Input
Possible Causes:
Related TP Sensor engine DTCs present Intermittent wiring or connector problem TP signal circuit is open or is shorted to battery voltage or to 5v supply circuit TP sensor has failed TP sensor ground circuit is open PCM has failed IAT Sensor is damaged or it has failed (an internal open circuit) PCM has failed
Jun 02, 2012 | 2002 Jeep Grand Cherokee
P0700, P0750 and P0755 codes I was driving at 65 mph and the 2003 Dodge Caravan down shifter to low gear and the check engine light came on. It will not ship to high gear.
P0700 (M)
Check Transmission DTC's
This code indicates that the EATX (Transmission controller) has an active fault and has illuminated the MIL via a BUS message. The specific fault must be acquired from the EATX via a DRBIII tool. (Input or Output Speed Sensor failures often cause this code and are a common failure part on WJ Grand Cherokees
P0750
Shift Solenoid circuit.
Note: If code P1767 (Transmission Relay Always On) is also present: Replace transmission solenoid assembly. See note provided. When transmission is in limp mode the relay that provides power to the solenoid group is switched off. This is normal and is designed to provide operation in one gear only. Engineering department suggests to replace transmission solenoid assembly anytime these two trouble codes occur together. See applicable service manual section (21) for solenoid assembly replacement directions. IMPORTANT: When performing this repair always check torque on all valvebody accumulator cover plate screws. Proper torque specification is 70 inch pounds. If any accumulator cover plate screws are damaged or missing replace the valvebody assembly. NOTE: If any other trouble codes are present do not replace solenoid assembly. See test in the applicable Transmission Diagnostic Procedures Manual
P0755
Shift Solenoid B
Oct 14, 2009 | 2003 Dodge Caravan
Mode Shifter Coil- How to check
it should read between o and 70ohms. if the light flashes 4 times it is out
May 17, 2009 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
