Question about Acer Aspire 3680 Laptop
Once opened, the computer easily shuts down and cannot re open again
  • 3 Answers
If the computer is turning on and shutting off right away then the chances are good that you are having a battery problem. Try popping the battery out of the back of the computer then putting it back in again.
If this fixes nothing try to return the battery and see if a new battery fixes your problem.
Posted on May 27, 2011
I can't open contacts and calendar in my mac pc
Shut down youre computer completely. Start again, but keep holding down the start button, until the white LED on the front flashes rapidly.
If this doesn't solve it, shut down your computer. Restart and hold down alt-cmd-p-r (4 keys) during startup until the computer has said boing three times.
Write again if it still doesn't work.
Mar 10, 2014 | Apple MacBook Pro Laptop Computer with...
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
Boot Error Shutting Down Sony NWD-B103F
Contact Sony Tech support via email. they should be able to help. it is free I think.
Jul 14, 2017 | Audio Players & Recorders
Hi, my zzr 250 hadn't been started for about 8 months, so it fired up nicely with the choke on but once the bike warmed up I couldn't get it to idle once the choke was off, i tried more air to the carby...
Could be one of two things
1. The carbs are gummed up. Modern fuel will break down after only a few months. The idle jets are quite small and will easily become blocked. Strip and clean the carbs.
2. The throttle cable is sticky. Less likely, but possible. Make sure it opens and snaps shut easily.
What do you mean when you say you tried more air?
Aug 04, 2010 | 1991 kawasaki ZZR 250
Power problem; Nonstop fan
Here is what you do, it is for unfreezing the bios. Open your computer and look for the bios clock battery it will be silver and the exact roundness as a nickle. you will be able to remove it rather easily the number should be CR2025 on the battery. you can buy these from most stores actually, radio shack, walgreen's. walmart, ect. before you leave for the store unplug your computer and hold the power button for 15 seconds, " this clears the power " leave it unplugged until you have a new battery, Once you have a new battery install it with the + facing in the open and the unlabeled side facing down into the slot. plug your computer back in and boot, it may cycle through the Bios restart once, from there it will restart again and you should be good to go.
May 26, 2010 | E-Machines W3107 (RBW3107) PC Desktop
Camera stuck open and wont switch on
The lens is jammed. There is an internal plastic ring with lugs/clips on it that is easily damaged and jams the lens.
Lens needs to be stripped down, repaired and reset
Oct 15, 2009 | Fuji FinePix F47fd Digital Camera
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Password
Try This:
How to Change/Reset a BIOS password Posted on 30 December 2008
Tags: Tech News, Tutorials If you are a normal computer user who has forgot his BIOS password and you are unable to access to your BIOS, then you need a simple way to change your BIOS. Its not that hard because you just need a simple trick to reset your BIOS password.
Open your CPU cabinet after switching OFF the power and then try to locate the CPU battery which can be found very easily. Once you locate your battery you need to remove it once and restart your PC without the battery.
cmos-battery-check.png Note : Once you remove your battery from the mother board, you will find that all your time settings in your computer would be lost, and some softwares may stop working which are based on your computer time.
You need to shut down your PC again and now add back the battery which will enable you the time saving feature and also reset your BIOS password.
Feb 22, 2009 | Microsoft Inspiron Notebook
I recently purchased a Toshiba A200 laptop. When shutting down, I pressed "Hibernate" and I now cannot get the laptop to start. Can you please help??
push the on/off button once, to try to open the comp (does not matter that it won;t open), than pres the button continuosely for about 6 seconds (to force it shut down) and than press again once to open ....
if that does'n work than depanding on the OS u;re useing, u have to force the OS to start in normal mode or to check it's self. (for windows, press F8, than u;ll have a start normal mode option ...)
Apr 22, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
