Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
We just bought White westinghouse Aqua Plus WWT101M fully automatic washing machine ang it keeps on saying E1 on the small monitor. what does this mean? i couldnt use the machine at all, the light are all on, the water suplier seem to be working fine. but its not spining, it not doing the washing. How do i solve this?
  • 1294 Answers
SOURCE: Westinghouse Top Load Washing Machine
Possible your outlet filter is blocked, it need periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first. Well, you have a record of sorts, 30 years!!
Posted on Jun 13, 2007
  • 1028 Answers
SOURCE: No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Posted on Jun 02, 2008
  • 36 Answers
SOURCE: clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
Posted on Jan 03, 2009
venexcsd
  • 1185 Answers
SOURCE: how do I replace the water level switch in my washing machine
You either need a new pressure switch or the pipe leading up to it via the air bell is blocked with a soapy jelly.
You can remove the back and then take off the plastic or rubber pipe leading down from pressure switch (It looks like a small flying saucer with several leads onto its plastic side and a small inlet pipe where the plastic pipe fits onto.
The other end will fit on top of a small chamber attached to the near the bottom of the main drum , this may be made of a translucent plastic which should allow you to see if there is any blockages.
If not it is a case of removing it making sure it is clean and if need be glueing it back into place with a good silicone sealer or instant gasket.
If that is clean and the machine still gets the levels wrong you need a new part
Posted on Jun 01, 2009
  • 415 Answers
SOURCE: leaking westinghouse 9.5kg washing machine
a hose has partially come off or a cut in the hose
Posted on Sep 06, 2009
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Holding water
    Good Day,
    Your washing machine is fully automatic?
    the washing cycle is normal?
    if yes do the same maybe it will help you.
    for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
    Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
    if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
    if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
    Nov 02, 2013 | Washing Machines
    Washer won't spin
    Good Day,
    Avanti washer repair
    Good Day,
    Nov 01, 2013 | Washing Machines
    Won't drain and showing F 01
    Good Day,
    Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
    Re; White Westinghouse Oven, M/N KS860GDD3 Just bought a small, 1962 home & it was equipped with this old oven. Please tell me the year this oven was manufactured to determine the age? Just old, but...
    Sorry but you have posted to the Washing machine forum ;-0(
    May I suggest you re-post to the oven one where you might get a more useful answer than this ;-0)
    Good luck,
    John C
    Mar 08, 2011 | Washing Machines
    Dear sir, I bought top loading fully automatic
    you can contact appliancerepairplanet.vstore.ca for help in this matter
    Dec 08, 2010 | Samsung Washing Machines
    My White Westinghouse 833ES never stops filling, it seems like as water goes in, it is draining right out. Any ideas of what to check would be appreciated. Thank you.
    you have to have the drain higher than the water level of the wahing machine, plus ther is no stopper for the water so if you have the drain hose connected directly to another hose and there is no air gap at the top it will just siphon out
    Aug 11, 2009 | Westinghouse Washing Machines
    Clogged screen for White Westinghouse washer
    Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
    Removing agitator
    Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
    Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
    Mar 28, 2008 | Westinghouse L1975NW Monitor
    Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
    130 people viewed this question
    Top Westinghouse Washing Machines Experts
    Dan Webster
    Dan Webster
    Mack Baxter
    Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
