Question about Vivitar ViviCam 8400 Digital Camera
Vivicam 8400- 'Scene' settings
I have just shamefully gone to use the 'scene' setting on my vivicam 8400 for the first time. I have had this camera for at least 18 months. After readinh the manual it says that you should turn the dial to 'scene' and a menu will display for a seconds. Then you should press ok, and choose the setting you would like to use i.e sport, night etc. The problem i am having is that this menu does not appear at all and there is no other way to access th settings. I really would like to use the sport setting and start experimenting with my camera. I have triefd a format, and resetting all to default. I have tried turning the dial to 'scene' whilst off, and whilst on, and neither makes any difference. please help!!
Thanks, Hayley
Grssd
Posted on Oct 14, 2008
I have an older model Vivicam 8400 with 8.0 mega pixel and 3x optical zoom. My daughter has somehow set the operating language to German and I need to know how to set it back to English. Please help?
see page 39 of
Vivitar ViviCam 8400 Owner Manual
1. Press the Down button to select the Language option.
2. Press the Right button for the 9 Language options submenu to appear: English ,French,German ,Spanish,Italian ,Portuguese ,Dutch ,Turkish ,Russian.
3. Press the Up/Down button to highlight and select the Language option you desir e.
4. Press the OK/Menu button to confirm and save your choice.
5. The camera`s operation language is now set to the one you selected.
6. Press the OK/Menu button to exit
Aug 28, 2016 | Vivitar Vivicam 8400 8.0 Mp Digital Camera...
How do I lighten the pictures?
Check your camera settings:
White balance should be set to auto,
ISO should be set to auto,
flash should be set to auto,
scene should be set to auto,
Exposure Compensation should be set at 0.
If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
Nov 10, 2014 | Vivitar ViviCam 7024 Digital Camera
How do I lighten the pictures? They are too dark.
And you did put the camera in automatic? and not in a scene mode, or something like that? I don't know if your camera has a setting like A, S, M or P, but you should not use these settings, unless you know what you want to achieve with that setting.
How to fix card error on vivitar vivicam 8400 digtial camera
see this and fix it. God bless you
The reset button is usually located on the base or the back of the camera. The reset button sets the camera back to the original factory settings. If the camera still does not power on, contact Canon support for servicing and repair.
Oct 17, 2012 | Vivitar ViviCam 8400 Digital Camera
How do you set the date on the Vivitar Vivicam X014?
1. Turn on the camera
2. Press the SET button (lower right).
3. Press the "trashcan" button ( to the right of the SET button) to scroll through the setup menu, 15 times, to get to the calendar icon.
4. Press the "ViviLink" button (below the SET button) to scroll down to "date setup."
5. Use the buttons surrounding the SET button (Scene, Trashcan, Flash, and ViviLink) as left,right,, up, and down arrows. Use up and down to change the month, then right to get to the date and up/down to change it, then right again to get to the year and up/down to change it, and so on through hour, minute, second, and AM/PM. Once the clock is set, press MODE to accept the settings.
6. You can scroll up and change whether you want the camera to timestamp the pictures - I turn this off.
7. Press mode again to exit the setup.
Aug 16, 2010 | Vivitar ViviCam 8025 Digital Camera
What does the different settings mean on my vivicam 5024
Your question is quite vague. Different settings on your camera are used to take pictures in different situations. Sometimes you'll need flash, sometimes you need a fast shutter or a slow one. All these things are done automatically by the cam, but by changing the setting you are preparing the cam to better suit the scene that you want to take as well as the resolution of picture you want and so on. If this doesn't answer your question, please be specific.
Feb 14, 2010 | Vivitar ViviCam 5024 Digital Camera
Blurry pictures from Vivitar Camera
possibly go to the menu, and go to quality, if it isnt set on fine, then change it,or, set your scene on auto, so if the pic is fast moving, it can adjust to take clearer pics. otherwise i am of no help.
May 21, 2008 | Vivitar ViviCam 5100 Digital Camera
Switching MegPixels???
Click the menu button (it's at the bottom right corner of the camera beside the trash can (delete) button.
Use the arrow keys to select Image size
Click the ok button
use the arrow keys to select your desired mp size
Click ok
Click the menu button and you're done
Oh yeah make sure the camera is turned on and set to Scene, A or P ( the dial at the top) to do this
Hope this helps :D
Mar 09, 2008 | Vivitar ViviCam 8400 Digital Camera
Driver for a vivicam 8400
You can download them for free from Vivitar here.
Dec 19, 2007 | Vivitar ViviCam 8400 Digital Camera
Time/Date Stamp Problem
I'm sure you have done this already, but you have make sure you press the OK button after all the fields are set. Something else, make sure the batteries are new and charged.
For printing the date/time...
  1. Rotate the mode dial to A, P, SCENE, Tv, Av or M and turn on your ViviCam 8400.
  2. Press the menu button, then use "right" to select Mode 3 menu.
  3. Press "down" to select the Daet Imprint and change it to ON.
  4. Press the OK button to make this permanent.
  5. Then press the menu button again to exit the menu.
After this, all pictures will print with the date, and cannot be removed.
Hope this helps, if it does, please choose FixYa!
Dec 04, 2007 | Vivitar ViviCam 8400 Digital Camera
Vivitar ViviCam 8400 Digital Camera Logo
62 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
