Question about Redcat Racing Volcano S30 1/10 Nitro Ready To Run
The volcano breakes do not work 100% WHEN RUNNING FULL SPEED AND I PULL THE BREAK, THE Tires do not stop like the shockwave. i bought new pads, tweack the screws,,,, nothing...maybe it is normal ?
I just got my Volcano S30 Friday, breaks worked great for 1 run not full speed, second run low speed no breaks at all, adjusted the linkage as requested by red at racing breaks worked good for 1 run then same thing no breaks, manually checked the breaks by hand the pad stops like it should except the wheels keep turning and the drive shaft as well.
Posted on May 14, 2012
  • 2336 Answers
SOURCE: Stuck Brake Pad Pins
I suggest pulling the axle out a bit to allow the caliper assy more freedom of movement. Then see if you can get the pins out. If not, you can put something (like a piece of wood) between the pistons and the rotor on the outside and gently pump the pedal to see if that does in fact loosen the pins. But a more fundemental question: is the new floating rotor the EXACT diameter as the OEM (or whatever was on there) rotor? It sounds to me like the rotor is jammed against the pins. If it is the same size, are the new pads the same shape as the old ones (same profile on the metal backing)?
Posted on Nov 20, 2008
  • 26 Answers
SOURCE: front right wheel bearing and break pads
Nope. 90% chance its your caliper pins. the caliper is required to float. When you remover the caliper by the two pins or whatever your application they require lube. if one is bent or seized the caliper wont float, the pads or pad will continue to wear because the caliper wont return to "neutral" location when the piston no longer has pressure on it. locate these pins and lubricate them with a graphite grease or something like lubriplate or similar. if the pins are bent remove them and replace. they're pretty cheap. good luck
Posted on May 02, 2009
mx5turbo92
  • 545 Answers
SOURCE: changing front and rare break pads in hyundia excel
this front::
  1. Raise and support vehicle, then remove wheel/tire assembly.
  2. Remove lower bolt and caliper assembly. Position assembly aside using suitable wire.
  3. Remove brake pads and shim.
  4. Bottom piston in caliper using suitable tool.
  5. Install new brake pads and attach shim to the outer pad. Tighten lower bolt to specifications.
this for rear::
  1. Remove axle nut, then the hub and drum assembly.
  2. Remove end shoe springs, cylinder and hold-down spring.
  3. Remove shoes and adjuster as an assembly.
  1. Reverse removal procedure to install, noting the following:
    1. Apply suitable grease to backing plate shoe contact surfaces.
    2. Install shoe hold-down pin, then assemble return spring with the pushrod shortened.
    3. Pull parking brake lever fully upward. Repeat process several times.
Posted on Jun 04, 2009
SOURCE: Can't get into the rear drum to replace break pads.
I have an 02 focus. Something popped and later the rear tire on the drivers side began smoking. I can't get the drum off to see what happened.
Posted on Jun 06, 2009
  • 87 Answers
SOURCE: 2004 Oldsmobile Silhouette abs and all wheel drive disabled light
MOST LIKELY A BAD WHEEL SPEED SENSOR/WHEEL BEARING ASSEMBLY.
Posted on Jun 17, 2009
Mercedes 270 ml break pads, fluid all been changed but break warning light keeps flashing and beeping on dashboard intermittently only stops when car stops
the new Mercedes need to reset the service interval with scan tool. find mechanic with advance scanner to enter the service mode on your car and reset the date for new service to 100% on all maintenance you do
Sep 27, 2014 | Cars & Trucks
My car vibrate at 100-120km/hr i have bought new tires and done the wheel balncing but it still vibrate and whenever i tried to apply the break at this speed it vibrate serously. it's a 2001 mazda mpv
This is due to poor settings of the wheel bearings,tyres,- check balancing once again, wheel drums/ brake pads,suspension , joints and steering.
In all the entire front suspension must be checked, the WHELL ALIGNMENT must be checked with precision and each of the wheels must be checked for damage on hub, axle or chassis.
Aug 08, 2011 | 2001 Mazda MPV
How to replace brake pads?
Jack up the front of the vehicle
remove tires
remove caliper,being careful not to break fluid line
using a c clamp squeeze the caliper piston back into caliper
install new pads in caliper
reinstall caliper onto vehicle
replace tires
lower jack
test brakes before moving vehicle to seat new pads.
Feb 19, 2011 | 2005 Ford F 250 Super Duty
My 99 Camry has done 400K. The blower motor fan stopped working. I checked thge manual, removed the resistor and tried a direct battery feed to motor to check if motor is OK. Motor started working on full...
you know the thing has run 400k miles, that is 300k past it designed life. break down and buy a new fan for it, it will set you back about 60 bucks. if you can replace the resistor, you can change the fan. a new set of plugs, plug wires, and a set of tires may be warranted as well.
Jan 12, 2011 | 1999 Toyota Camry
When i began to break it feels like I am not going to stop. It shakes so bad it thrusts you all over. I have had 4 wheel alignment, new tires, replaced ball joints and the breaks.
replace front rotors and pads with new napa parts only that should fix the brake issue and make sure you bleed the brakes.
Aug 09, 2009 | 2005 Ford Taurus
2001 Ford Ranger SRS brakeks and bearing problems
Your truck has sealed bearings in the front but they can go bad after several miles. If the truck is not stopping straight or you are getting a pulse through the break pedal (and sometimes a shimmy in the steering) then it's time to replace the rotors and pads. If the truck is stopping and driving fine then I wouldn't worry about it.
Jul 17, 2009 | 1990 Ford Ranger SuperCab
The oddometer works but the speedometer doesn't in my 1992 Dodge Ram pickup. The gear that sits inside the transmission is not stripped and engages fine. Can the problem be somewhere other than the...
Could be a bad cluster. If one is cable driven, and the other electric. You could have a bad speed sensor in the transmission which will make the speedo not work.
Jun 09, 2009 | 1992 Dodge Ram 250
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Brake job?
the best way to tell is by taking the tire off and look at the brake pads. if they are getting thin you should replace them.
Dec 04, 2008 | 2007 Rolls Royce Rolls Royce Phantom
Redcat Racing Volcano S30 1/10 Nitro Ready To Run Logo
178 people viewed this question
Top Redcat Racing Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Redcat Racing Toy Expert? Answer questions, earn points and help others
