Question about Sylvania LC320SS8 32 in. LCD Television
Sylvania Tv has picture but no sound
My sylvania TV has a picture but no sound. It just happened after I moved it to my friend's house and connected it to the cable box.
SOURCE: How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
Posted on Feb 16, 2010
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
Posted on Oct 29, 2008
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
Posted on Feb 17, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: Comcast remote code for sylvania lc427ssx
I had the same problem, I ended up buying an RCA Universal remote, when I had no luck with the codes I tried the autoscan feature, to my surprise it worked perfectly.
Posted on Aug 20, 2009
Our tv doesn't have sound or picture
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Apr 16, 2010 | Sylvania 6520FDE 20 in. TV/DVD Combo
Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
Jan 17, 2010 | Sylvania LD320SSX LCD TV
TV HAS SOUND BUT NO PICTURE
replace the H.O.T horiz. Driver Transistor.
comen problem with this set.
Jan 13, 2009 | Sylvania 6432TE 32" TV
Audio on Sylvania TV
You'll have to take the TV in for repair - this is not a DIY possibility unless you're a technician familiar with audio circuits.
Dec 24, 2008 | Sylvania 6427TE 27" TV
Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Nov 08, 2008 | RCA RCU600M Remote Control
Sylvania 13 inch -- model unknown
Hi DiBd. Some electronic components in a tv can go out of tolerance during long periods of inactivity. I think that's what's happened to your set. Some component in the video section of your tv has given up.
Greg.
Aug 13, 2008 | Sylvania 6413TC 13" TV
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Sylvania LC320SS8 32 in. LCD Television Logo
354 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
