When i install my ATi radeon HD 4650 AGP card on motherboard the monitor does not boot. But when i connect the monitor cable to the onboard video card it boots well. Why
  • NickPease May 27, 2011
    Are you running your onboard card and your 4650 in Crossfire?
  • 69 Answers
Depending on the OS you are running. Check to make sure that the device drivers were installed correctly while plugged in to the on board.
To do this on Windows:
open Device Manager by right clicking My Computer and clicking properties. From there you can click Device Manager (if on XP click on Hardware Tab).
Once there, you should see a selection that reads Display AdaptersWhen i install my ATi - logicaldemen.jpg
If it is installed correctly it should look like the one above (substituting in the ATI card)
If you see it and it has an ! or flag you need to update or install the drivers which you can get from http://support.amd.com/us/psearch/Pages/psearch.aspx?type=2.4.1&product=2.4.1.3.37&contentType=GPU+Download+Detail&ostype=&keywords=&items=20
Hope this helps
Posted on May 27, 2011
Ive installed the ati his radeon ice q graphics card and my computer will not boot,Why?
hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Jun 07, 2011 | MSI KT4V (MS-6712) Motherboard
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
Dec 21, 2010 | ATI RADEON X1300 PRO, (256 MB) AGP Graphic...
How do you disable the onboard graphics on an emachines C2825? I am attempting to install a Sapphire Radeon HD 4650 AGP video card, but my computer will not boot when i plug in the new video card. I have...
First of all that motherboard is too weak to fully use that video card, you could get the same framerate in games using a video card 2 generations older.
Proper way of installing a new card:
1. uninstall the driver of the old one and reboot in BIOS - in there put all settings to auto;
2. shutdown the pc and install the new card; connect the monitor to it;
3. boot into BIOS, disable the onboard video card and reboot;
4. boot normally and install the driver.
Jul 24, 2010 | Intel D845GVSR Motherboard
Gigabyte Radeon HD 4650 1GB (AGP) - unknown PCI device
Hello.
ATI (AMD) does not "technically" support AGP products, but go to this link.
http://support.amd.com/us/kbarticles/Pages/CatalystAGPHotfix.aspx
To download the driver. Versions 9.6 and 9.7 will work, depending on your OS. Just download and install the drivers and the yellow exclamation mark will go away.
For more information please visit: http://forums.amd.com/game/messageview.cfm?catid=260&threadid=117644
Hope that Helps.
Jan 29, 2010 | Gigabyte RADEON HD 4650, Video Card
Instaling video driver problems
You may need to change priority for onboard/PCIe in BIOS. Or to disable onboard video chip.
Dec 01, 2009 | Asrock P4i65GV Motherboard
Monitor goes black after windows boots up
Try removing the video card, and look up your motherboard / system manual on dell's website on how to manually reset the bios.
1. Remove video card
2. Reset BIOS (physically opening the computer and using a special jumper and/or removing the battery...what ever the manufacturer says to do to reset the BIOS).
3. After BIOS is reset, try booting up via your onboard video card first. Once you get that working, go into the bios settings and make sure it is set to boot the onboard only for right now and then you can make sure the ATI software is fully uninstalled when you get into windows.
4. Reinstall the ATI card and boot up with the video still connected to the onboard card. See if it will let you install the driver.
The trick here is to reset the bios and get the system booting off the onboard card if at all possible. If that works, then you can always reinstall drivers and then tweak the bios to boot off the AGP card instead of the onboard.
May 01, 2009 | Rosewill RADEON 9200LE (128 MB) Graphic...
ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Feb 18, 2009 | ATI Diamond Multimedia Stealth RADEON HD...
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Computers & Internet Logo
David Payne
David Payne
