I can use headset but my pc has no external sound
  • 3 Answers
Many computer speakers have their own seperate volume control, which in conjuction with your PC's volume control will create a compounded volume.
If either volume is set to zero, in this case probably your external speakers, no sound will come out. Try looking for a volume control on your speakers.
If that's not the case, it is possible that your speakers are not plugged in properly or are not turned on. Remember that they should need their own AC power supply (wall outlet).
If neither of these resolves your issue you may try contacting the customer support for your specific speakers.
Posted on May 27, 2011
  • 336 Answers
TRY CONNECT THAT SPEAKER TO OTHER COMPUTER FIRST. THEN ALSO CHECK-UP POWER ON LED , VOLUME CONTROL AND AC PLUG.
No sounds comes out in headset but external volume is ok
Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
Apr 01, 2012 | Computers & Internet
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
My laptop speakers are not working but there is sound when i attach headset
once cause is that your onboard speaker on your laptop was already been busted, My suggestion is better to use headset or external speaker. Or also try to navigate control panel and go to sound settings then check if their is an option for internal speaker being used. If not then better to use your headset or external speaker. Hope it helps thanks.
Sep 13, 2011 | HP 530 Notebook
No sound when i connect my dx2300 to external audio amplifier or other external sound system but internal speakers are o.k and working! why is this Mesh In nairobi Kenya
If the Internal speakers are working fine that means your Sound card and settings are fine. Just check the Cable, pin and the port you are plugging it into. Or else try connecting a headset on the sound card port to diagnose clearly.
May 22, 2010 | HP Compaq dx2300 Microtower - RT950UTABA...
I have the headset with the jack hook up not usb and I would like to know how to get music to come through my computer speakers while I'm talking on my headset and hear the person I'm talking to through my...
You are using one sound device at a time, this is not possible, if you like to be able to hear from headset and play music on your pc at a time, you must have a USB Amplifier and Headset (eg: GN Netcom, Avaya, etc...)
first you must set your Media Player's Option to Devices>Speakers>Audio device to use> DirectSound of your PC.
The other one is your are using a program to talk to other people, that program also has a feature to select the Audio devices to use, you must select that other device like my example above.
Hope this is clear enough to help you out.
Oct 21, 2009 | Computers & Internet
No sound come through external headset or desktop speaker
Sometimes the headphone jack has its own volume control separate from the internal speakers. Check the levels in the volume mixer.
Apr 22, 2009 | Acer Aspire 5500 5570-2609 Laptop
HP dv2000 external sound problem
Yes, the slot where the jack goes is faulty.
Common problem in all DV series.
Mar 22, 2009 | HP Computers & Internet
I want to use external speakers and USB headphones in harmony
right click at my computer then click properties then click hardware then click the device manager did you see the yellow ?mark right click the device then update the driver then choice the best driver for your C-Media A97 list of drivers will appear then the best one
Mar 23, 2008 | Computers & Internet
DELL LAT INTERNAL + EXTERNAL NO SOUND
assuming headset is right connector, right? and they work elsewhere? that's the only reason headsets don't work, is that the jack is incompatible with the socket for speakers..
Feb 21, 2008 | HP Compaq Evo n610c Notebook
97 people viewed this question
 Grubhead
Grubhead
