I think we had a power surge and my jamo i300 speakers have stopped working, how to open the subwoofer, i've tried undoing the 10 screws around the edge........
    Brigadier General:
  • 8,546 Answers
Perhaps some triage first before you open it up.
Are you sure it's just the speakers that are 'damaged'. The control dock is a vital link in this. Try other sources attached to IT. Or a source plugged into the Line Input directly on the back of the sub. Identify the correct patient before doing the surgery.
Posted on May 27, 2011
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
What batteries to put in the jamo i300 remote control
Remote Control Battery Replacement
To replace the battery, remove the two screws on back of the
remote and disassemble. It is a "Button" type battery not sure what the number is but look at the battery and find the number on it and replace it with the same style battery
To download a free owners manual go to this website
http://www.jamo.com/na-en/support/owners-manuals/
Jan 14, 2011 | Jamo I300 Docking Station
How to open the subwoofer housing to change the fuse
on the back unscrew all the screws (there should be 8 in the plastic square around the jacks... and then undo the four that are in the wooden back) then pull out the plastic square, it will take a decent amount of force, try prying with a flat head screw driver. Once you have that out, you should be able to access what you need inside.
May 30, 2010 | Altec Lansing VS4121 Speaker
Jamo i300 dies after powercut
If its out of warranty you might as well open it up , and if your lucky it might only be a fuse to replace , if it is fused inside it will probably have blown before it could do any damage to circiuts . hope this helps
May 25, 2009 | Jamo A 102 HCS 5 System
Jamo i300 speakers are dead.
There is peobably a fuse located on the back. Your speaekers are probably okay. If anything fried inside, it is probably the output transistors.
Feb 02, 2009 | Jamo A 102 HCS 5 System
Not working until the power switch is toggled
Try turning up the sub output on the onkyo.
Aug 05, 2008 | Velodyne CHT-10 Subwoofer
Jamo subwoofer issues
hai iam hans i had also a problem with the sub
turned out jamo denmark didnt had the spare parts to fix it?
can u believe that
so i wait 6 weeks and after 100 phone calls to denmark and my local dealer they deside to take the part out of another sub ?.
but i really had to make a a lot of effort to achive this
but for the price the jamo set is exellent
a shame about the service .
Jan 14, 2008 | Jamo A 102 HCS 5 System
168 people viewed this question
 Grubhead
Grubhead
