Question about Garden
I was sign in to my skype account.and suddenly window closed.then again i tried to open it.But it says you are currently sign in to your account, please sign out.But i can't open my skype to do anything.Am stuck.Please help me. Thank You.
  • 3 Answers
There are several solutions to your problem, all of them will involve exiting skype and then signing in again.
As a first step, you could try to close the program, this can be done by:
-Press CTRL + ALT + DELETE together at the same time.
-Select the option that appears labelled "Start Task Manager"
-Select your Skype application in the "Applications" tab
-Press "End Task"
If this does not work for any reason, a new option would be to restart your computer.
If this does not work for any reason, try getting in contact with Skype support and identifying your problem to an employee.  https://support.skype.com/en-gb/
Posted on May 27, 2011
I created a Skype account and now i have no idea how to delete it .
Unlike some other programs, Skype does not allow you to actually delete your account.
This means you will still show up if and when others search for you or try to add you as a contact.
You can, however, delete your Skype account from your PC.
Doing so removes the account in question from the list of options available when you sign into Skype.
Log out of Skype and quit the program entirely.
Click the "Start" button in the lower left corner of your screen, then type "run" (without quotes) into the "Search programs and files" field that appears.
Click the Run option under Programs in the list of results.
This opens a new window.
Enter the term "%appdata%\skype" into the new window. Do not include the quotation marks.
Click "OK." This opens another new window.
Locate the folder that has the same name as the account you wish to delete in the list that appears in this new window.
Right-click this folder, then click "Delete" in the list of options that appears.
Click "Yes" in the window that pops up to ask if you are sure you wish to delete the folder.
You have now successfully deleted the Skype account from your PC.
https://support.skype.com/en-us/faq/FA142/How-do-I-delete-my-profile-or-Skype-Name;jsessionid=8287384E7091693136A628A5B03714BD
Can I delete my Skype account
Sep 08, 2013 | Computers & Internet
I want to creat new skype id
I got your answer from: https://support.skype.com/en-us/faq/FA829/How-can-I-run-two-Skype-accounts-on-the-same-computer
In order to use more than one Skype account on the same computer at the same time you need to start a new instance of Skype:
  1. From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
  2. In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get any error messages, please copy and paste the exact command from this email and try again.
Please keep in mind that if you have changed the installation path for Skype then you need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
  1. Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
  2. Right click on it and choose: Send to > Desktop (create shortcut)
  3. Locate the shortcut on the desktop, then right-click on it and choose Properties
  4. In the Target field, add: /secondary. The Target field should now be: "C:\Program Files\Skype\Phone\Skype.exe" /secondary
  5. Click OK. You can now start a new instance of Skype every time you double-click on the new shortcut.
For Skype 3.8 and earlier Requirements: Windows XP, Two Skype User accounts
First, create a new Windows user by going to the Control Panel and clicking on User Accounts. Choose Create a new account and follow the steps to set permissions. We also suggest setting a password for the new user by clicking on the newly created user and choosing the Set Password option. The new user will also require admin rights on your PC.
Next, create a shortcut to Skype or make a copy of the shortcut that is already in the Start menu. Right-click this new shortcut and choose Properties. On the bottom of the first page there is a button labelled Advanced... . Click this button and select Run with different credentials. Select OK, and then select OK again to close the Properties dialog.
You're all set. Whenever you use this new shortcut it will ask for a Windows username and password. Enter the Skype Name and password of the user you created earlier by choosing The following user: option. Click OK and you'll have a second instance of Skype. It will require that you sign in with your Skype Name and password the first time.
To help automate the Run as trick you can create a second desktop icon for Skype and modify its properties. Click the Advanced button and check the box Run with different credentials. After clicking on the modified icon it will ask you to sign in as another user. Changing the icon graphic also helps ensure you click on the correct icon.
If you have multiple USB headsets or USB Phones you should be able to set up both instances of Skype to use a different sound device.
Dec 02, 2011 | Skype IM
Hi my husband has skype set up on our lap top. Can i set it up too? Do i have to download it again or is there a way i can do it through the desktop icon?
You want a second account, for yourself? If your Skype logs in automatically when you start it... See the menu in top of the window? Go to Skype and select Sign Out. Then you will see the Skype welcome screen and the option to create a new account. Does that answer your question?
Sep 05, 2011 | Skype IM
How to install skype on hp loptop
Download the installer if you don't have one yet at skype site. Enjoy
Mar 16, 2011 | Computers & Internet
Hlep me to create skype id
go to Skype.com, download latest version in Yourlanguage,
that's what Skype itself tells us to do:
To start Skype:
If it's your first time opening Skype: Open Skype on your computer.
That means double-clicking this icon on your desktop or choosing it from theWindows > Start menu. Having trouble? Launchit from here. This will open a start-up screen. Click Don't have a Skype Name?
This opens a Create account window. Type in your name, then create a Skype username(called a Skype Name) and a password. - Pick ones you can remember so you can sign in nexttime. - Follow the directions from there and click Sign in. If you've opened Skype before: Open Skype from your desktop or Windows - Start menu. In the start-up screen, click in the box under SkypeName and type it in. Then do the same for your password.
(If you forget your password, click the Forgot your password? link and followthe directions from there.) This will sign you in to Skype, ready for you to use. Happy Skyping Greetz Ganimidis
Mar 04, 2011 | Computers & Internet
Cannot login to my account
From http://heartbeat.skype.com/
"Sign in and registration. Some customers or areas may currently experience problems." Dec 21, 2010
Dec 22, 2010 | Skype IM
I am trying set up a new skype for children but it seems i cannot open as follow the password.
when you are setting up a skype account, an email account is required in setting up a skype account. when you want to set up another skype account, you will need a different email address in setting up a different skype account. after seeting up this new skype account, if you prefer using both skype accounts on the same computer, on the skype window during singing in, you will have to uncheck the box that says SIGN ME IN WHEN SKYPE STARTS. imput your usernames and password and sign in. I hope this solution is useful.
Dec 15, 2010 | Microsoft Windows XP Home Edition
How do i get my skype name and pass word available so i can sign in.
Create an account with Skype using this form (click here), provide all the information and type in the captcha at the bottom of the page and click "I Agree - Continue" once you are done, confirm your email [so you must use a valid email address]. There, your account is activated and you now have a skype account. If you haven't download/install skype on your computer, then you can download it from here (click here), open the link and click "Get skype for windows" [if your computer's operating system is windows] or similar button. On the next page, click "Download Now" [if you already signed in, download will begin automatically, but if you haven't signed in, you need to do so].
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Skype IM
I have been using skype for some time now...today I can't seen to get into my skype..it will ask me for my e-mail and password but it can't find it..should i download skype again
visit first skype.com then sign in, if you cannot open your account it means your email ad and password didn't match you may check that things. But if your account will pass this thing you may better to dowload new skype again, maybe your old skype corrupted thats why you cannot open it. Thanx
May 09, 2010 | Skype IM
Web cam
Dear Digjay,
Please Rate this solution.
for using webcam in yahoo messenger,all you have to do is go to the yahoo messenger settings and set the camera. On the bottom of my messenger there is a camera button that turns the cam on.
for installing skype
Downloading and Installing Skype Step1 Go to the Skype Web site (see the Resources section below for links to download Skype for Windows, Mac, and Linux users) and download the SkypeSetup.exe executable. (The executable gets downloaded under the Program Files folder under a directory called Skype that gets automatically created. A Skype Setup icon is also automatically seen on your desktop.) Step2 Click on the SkypeSetup icon that is on your desktop. A Skype Setup wizard then appears. You will get a warning window asking if you want to Run or Save this file, SkypeSetup.exe. Click Run. Note: Another confirmaton message may come up asking if you are sure you want to Run this software. Click "Run" again. Step3 Follow the instructions on the Skype Setup Wizard to complete the installation of the Skype software. At the end of the installation you will be asked to setup a Skype account. Step4 A Skype window appears and if you have never used Skype before you have the option of creating a Skype account. A link is seen on that window mentioning the following: "Don't have a Skype name?" Click on this link and it opens up another "Skype - Create a New Account" window where you have to type in your Full Name and then you have to type in a "Skype Name" and a Skype "Password" and "Repeat Password" in the respective fields on that window. Note: Jot down this Skype Name and Skype Password as you will need it everytime you open the Skype application. Step5 Click on the "Sign in" button. Note: After having created this new Skype Name account for the first time, the next time you open Skype again, your Skype name will automatically appear in the Skype name field. All you need to do is to type in your Skype password and click the "Sign in" button. Step6 Follow the instructions in the "Getting Started" guide to "Add a Contact" using the "Add Contact" button, to test your headset and microphone using the "Skype Test Call Feature," to set up a Conference Call with a business colleague or friend, and to explore all the other features in Skype. Step7 Once you have installed the Skype software, there are 2 ways by which you can open the Skype software application. Click on the Skype icon on your desktop Or Double click on the "x" icon in your desktop's system tray to start Skype at any time. Note: Once the Skype window comes up, the "x" checkmark then changes to a green checkmark to indicate that the Skype application is currently running on your computer. It changes back to an "x" mark when you have "Signed out" of Skype and Skype is no longer running on your computer.
Please rate this solution.Thank you.
Dec 17, 2008 | Computers & Internet
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
