Question about Samsung SCX 4521F All-In-One Laser Printer
SCX 4216F All in One Monochrome laser printer. Paper Jam and printing stops half way through with "Paper jam"
  • R. Walden May 06, 2009
    Paper stops about 3" after heat fuser with a paper jam error but there is no paper jam.
  • 22 Answers
From other information listed I was able to answer my own question. On this model there is swingarm right after the fuser that verifies the paper made it through the fuser. It's shaped like a lightning bolt symbol or stretched out letter "S" and has small round sticking from each side near the middle point; on the one end there is a small flat square. The part pops into a matching holder and when the paper comes through the fuser it pushes one end of the part causing the flat part on the other end to swing and pass between 2 sensors (magenetic?) which creates a signal and tells the brain of the machine that the paper made it through the fuser. I found this by opening the back where the fuser is located and saw the part laying there and how once I put it the right way it go right between those sensors (or maybe called pick-ups). I know what caused the arm to pop out; a huge paper jam on a humid day when somehouse 6-7 sheets managed to stick together and either they knocked the swingarm off or I did when clearing the jam.
Posted on Sep 14, 2009
  • R. Walden Sep 14, 2009
    Seems odd responding to myself - my expertise is in air conditioning. Apologies for the missing words and mispellings - another all nighter on the computer.
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Paper jam in exit area
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
ON Samsung SCX 4216 Error: Paper Jam 0 Open/Close Door Can't find any paper stuck in it. Error does not go away even when turned off and on or unplugged.
Hello! Welcome to FixYa
Paper jam
means their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow" by compressed air.
more over roll the toner gear check if its not obstructing to something .
secondly try to cut/delete any pending print jobs thats right next to clock on your dektop.then restart PC and then plug the printer and PC on see if it works.
If still problem exist then, post your query here ,
I hope this solution will helpful for you
Anymore help regarding the issue, I am here to help
Apr 05, 2011 | Samsung SCX-4216F All-In-One Laser Printer
I'm trying to print and i always get a paper jam in door one. If I open the back door, the paper comes out 1 inch and stops. The paper is getting 95% printed on and then gets jammed. I changed the toner...
1. You have to clear paper feed roller
- to do this just follow simple steps:
- open fron cover
- remove toner cartridge
- use wet cloth (water or alcohol) to clear rubber feeder
- put toner cartridge back
- close front door
2. If the problem persist - chek all paper path sensors for lack of moving.
Oct 05, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Paper jam
at the back of the mashine there is a litle door you can open take the paper out from there
May 31, 2010 | Samsung SCX 4600 multifunction Laser...
Paper Jam 2 displays however there is no paper jammed in the machine
This is caused by exit sensor or the problem may be a small peice of paper is still remaining. Or if its software error which will be cleared from service center. Please approach them.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Noise crunches paper wont eject fax
you have a worn fuser drive gear and a worn fuser
Dec 23, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F feed wheel
Clean the Feed Roller In the middle of the printer. Take the paper tray out- you will see the roller in the middle. Send a print job with paper tray removed. Press the black thing to fool the printer that it has paper. You will see the feed roller move. When it is in the position you want to clean- open the toner door and it will stop moving so you can clean it. Isopropyl alcohol and LINT FREE CLOG.
Nov 07, 2007 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
153 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
