Question about Frigidaire Refrigerators
What kind of small like rubber buring from refrigerator?
Smells like burning rubber
Good afternoon friend, thank you for your post!
I understand that you are receiving a burning rubber smell from your Frigidaire refrigerator. I would like to ask you some additional questions to better assist you. How long have you been experiencing this smell? Have you noticed any additional symptoms? How often do you smell it? With this additional information I can provide further assistance. I look forward to your response. -Matt
Aug 24, 2014 | Frigidaire Refrigerators
What's your problem?ice buildup under french drawer refrigerator
It could just be condensation, especially if you live in a humid area. I'd consider adding some silica gel packets (the kind you find in shoeboxes,) to the place where the ice is building up and see if there are holes in the ice where the silica is. If so, it's moisture-based, and short of installing a dehumidifier in the house or running the AC constantly, your best bet is to invest in a thick rubber mat, like the kind offices have at the door, and place the fridge on it, possibly with a small one-inch-thick block of wood under each foot. That's what I had to do and to my surprise, my power bill went down. It turned out that the rubber mat caught the condensation and let it evaporate, plus the wooden blocks gave the refrigerator coils more ventilation, which made it run more efficiently. It was like a $5 difference per month on the electric bill, so definitely worth a try, plus if the rubber mat is rectangular, it'll protect the patch of floor in front of the fridge from any accidental spills.
Aug 29, 2012 | Cell Phones
Electrolux cylinder vacuum No suction and loud noise and smell of buring rubber
rollers are probably stuck the belt is burning check for restrictions in you hoses as well as in the vacuum as well if nothing else works a repairman
Jul 13, 2012 | Vacuums
Heating extremely fast and smells like burning rubber
If it is a belt driven dryer the belt may be spinning on the motor shaft and it may be bad. Hence the burning rubber smell. Have it checked.
Dec 02, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
I am geeting water on the bottom shelf of my
There is a defrost drain located at the rear wall inside the frig.
I usually take a large syrenge with a rubber hose attached to it. I fill it with hot water and insert it into the drain cup sealing it to the small hole at the rear of the cup. Force the hot water through the hole in the rear of the cup and this should clear anything stuck in the drain.
I hope this helps.
Dec 31, 2009 | Refrigerators
Hello, I have a problem with my Eureka Powerline bagged upright vacuum. It has a 12 amp motor and is model #4352, Type D. It was probably bought new in 1998. My problem is, while vacuuming today the motor...
it sounds like a rubber sealing in the motor has come loose and is being constantly rubbed against the walls of the motor with would cause the smell and loss of motor speed caused by the fricton of rubber against the rod so if you can get to the motor try to open it and see if you can get it if not take it to a small engine repair service hope this was helpful:)
Nov 16, 2009 | Vacuums
Our Crystal Cold propane refrig freezer unit keeps everything frozen but the refrig portion isn't keeping things cold and we've had to throw out a bunch of food. Any suggestions on what the problem could...
I am working on similar problem on my Crystal Cold refrigerator. I've found the seal between the  main door and the refrigerator body is starting to gap. We've also recently noted a few small flies in the frig. To diagnose, I took a butter knife and gently tested small gaps in the seal and found the ones on the lower left of the door (facing the frig) went all the way through. I'm on line now looking for a good price on new seals. They may be as much as $100. I may, if I can't get a better deal try some foam rubber window seals, the kind that comes in small rolls.
Aug 19, 2009 | Refrigerators
Maytag dryer does not start.
if you are smelling rubber the motor is spinning but the belt is not.you may need a new belt and the idler pull may need replaced also.
Jun 17, 2009 | Maytag PYE2300AY Electric Dryer
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
