My system model no vt8366-8233 has not the system sound without external speakers
  • Computers & ... Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 27, 2011
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
No sound is coming out of speakers, but sound drivers are installed
It could be that the speaker is not connected properly or it has gone bad. It could also be an outdated sound driver. It's better than you update the sound driver before fixing the hardware part of it. You can use RadarSync to auto-detect the updates and you can use the same software to automatically update them without you downloading anything or something like that from the manufacturer's website.
David
Mar 17, 2013 | Audio Players & Recorders
The sound has stopped working on our GeoSafari LAPTOP No. 8545. Help!
Hi Lisa,
What operating system are you using?
Check that sound is enabled in both the operating system and BIOS.
Check that you have the volume turned up.
If you have an external set of speakers, try plugging them in and see if you get sound. If the external speakers use a power supply, make sure you have the speakers powered and turned on. Computer speakers almost always require power to run the internal amplifier. Computers sound output is so low that regular speakers can not be used. Also, if you have a set of headphones from an iPod or similar device try the headphones. Headphones are sensitive enough to work without power.
Aug 06, 2012 | Computers & Internet
Remote has locked sound for my tv,how do i rectify?
I assume you are not talking about the mute button.
Do you want sound played through the TV speakers or through an external sound system? I once worked on a TV that was set to mute the internal speakers and send the sound only to the external sound output jacks (fortunately the owner remembered he had done this before we got into the sound circuit - the set had been out of commission for a while with another problem).
Without knowing what model you have, I can only suggest you look through your manual for instructions on setting up the TV for use with an external stereo receiver. This may tell you how you got there so you can figure out how to undo it. If you don't have the manual, you'll have to hunt through the on-screen menus for the sound output setting.
Oct 24, 2010 | Televison & Video
Can i connect speakers to my 47ich plasma tv without a surround sound system
I would need the specific model to tell you for sure. But most plasma's do not have that ability as they would need an external speaker amplifier built in which they do not do. So most likely the answer is no.
Thank you,
Lee
Aug 10, 2010 | Philips Televison & Video
How do I hook up external speakers?
You should have 3 small round recepticles on either a sound card at the bottom of the back of the tower, or in your system board which may be further up. These recepticles are usually green, white, etc. They may have small markings showing which one is for an external microphone and which one is for speakers or earphones. Without knowing what make or model of computer you have, it is hard to be more specific.
Brian
Mar 02, 2010 | Computers & Internet
The sound on my Dell laptop has suddenly gone very tinny and distorted. Does anybody know what the cause may be and how I could fix it without calling Dell in India?! Thanks
I would use the audio output of your netbook to supply signal to any external audio system so you can determine is it is an internal circuit problem or simply a failed speaker. If the distortion is present in the sound output from the external system, then a circuit in the netbook has failed. If it isn't audible in the external system, then a junky speaker has failed in the netbook.
Oct 24, 2009 | Samsung NC10-14GW Notebook
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
Plug in external speakers w/ volume very low in HP2009m screen
check if the external speakers u plugged in came with an internal amplifier, if not then u will have to use an external amplifier to get max output from your external speakers.
Sep 02, 2009 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
