Question about JVC Everio GZ-MG630 Hard Drive Camcorder
My lens cover will not shut. - JVC Everio GZ-MG630 Hard Drive Camcorder
    Genius:
  • 1,812 Answers
The lens cover mechanism in these cameras is susceptible to debris and requires disassembling the camera to repair. This can be repaired fairly inexpensively. However, it's not a user serviceable problem due to the fact that the camera will need to be partially disassembled and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
Posted on May 27, 2011
I have Sony VPL CS6 projector and the lens cover stays open and wont shut to cover the lens!! The Lens/Cover light on it flashes? It does project for about 15seconds or so but then goes off, this is when...
It is possible that there can be few reasons for the fault siad:
1.the lamp can be faulty
2. the filter can be clogged.
3. the lens cap trigger switch can be faulty and staying on
4.The power supply can be faulty, not delivering the power but shuts off.
5,the main processor board can be faulty witth errors.
It might need board swapping to confirm.
Sep 25, 2010 | Sony VPL CS6 Multimedia Projector
Camera is always shutting down even if its not low battery.
This is what usually happen when the battery power is too low to drive the lens motor that results in the camera using more battery power to close the lens causing the lens to jam and shut down. you can retract the lens ,replace the batteries and also check the warranty cover for the camera if still under warranty you can return for possible replacement
Jun 06, 2010 | Samsung Cameras
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
Jun 30, 2009 | Nikon COOLPIX S51 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Black screen, loud beeping when opened, doesn't work
The following blog outlines some simple repair options for a lens error. But please first try the listed Fix #2. I heard that fix particularly works well for a camera who's battery had run down with the lens open. Please post back here with a follow up comment if any of the fixes work:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 23, 2007 | Canon PowerShot S60 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
The lens cover wont open
If debris like sand or dirt get into the mechanism which closes that cover it will jam shut. Try gently placing something pointy in the gap between the two blades of the cover. Do not force them apart, if this is going to work they should free with very little pressure. Be very careful not to touch the lens especially if you are using something metal to separate the cover. David Millier Advance Camera Repair
Feb 13, 2007 | Nikon COOLPIX L4 Digital Camera
Lens wont shut completely
hello, as you said lens cover does not shut it means camera is in working mode so naturally it drains the batteries. Actually the problem is in the lens assy. so go to samsung shop. good luck...
Jul 27, 2006 | Samsung Digimax S500 Digital Camera
JVC Everio GZ-MG630  Hard Drive Camcorder Logo
103 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
