Question about Hoover F7220900 SteamVac V2 Upright Vacuum
The brushes on my hoover steamvac widepath wont turn the filter is clean model # f-6024-900
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
Posted on May 15, 2008
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
  • 4090 Answers
SOURCE: My hoover F745 900 steamvac brushes will not spin.
If you are handy with a screwdriver undo the casing to access the roller. Once open usually about 4-5 screws you will see that the drivebelt ( rubber band ) has broken. This is the piece you need to replace. Usually most electrical store selling cleaners have these. Take the piece along or get the part number from the manual and replace it yourself. Cheaper than having a tech do it at $90 an hr plus the $5 part
Posted on Jul 22, 2009
sawdust46694
  • 398 Answers
SOURCE: Brushes wont rotate
the belt has streached go to walmart and get a new one.
Posted on Aug 13, 2009
SOURCE: agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Posted on Sep 06, 2009
Brushes donot turn when asked to shampoo
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Hoover SteamVac Replacement Turbine Brush Gear Part # 91001097
F7425 Parts Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Feb 09, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Agitator brushes wont turn even after cleaning
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don't turn
I had the same problem and found a manual online. I never realized that there was a filter in the bottom of the machine. There are 2 red tabs, squeeze them together and pull ( I had to use a pair of pliers to pull). Note which is top and which is bottom tab. Clean the filter and reinsert. My brushes are now spinning!
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes don't turn.
no belt. the turbine that turnes the brushes is the problem. how can you tell......take the brushes out and try to turn the square peg with a flat head screwdriver, if it doesn't turn, it's the turbine.
Jul 19, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover all terrain steamVac brushes wont move. Does this model have a belt and where
The brushes are driven by air flow (suction). the most likely problem is with the turbine. This part can be replaced or repaired. If under warranty, take it tin for service, otherwise you will void any warranty.
Sep 03, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
