Question about Cameras
I have a flip Ultra HD 2nd gen model: u2120B. I bought it off of eBay, broken. The buttons don't work. The camera is seen by the computer when plugged in. I can format the camera HD and reinstall the software. No change. When I turn the camera on, it goes directly into setup, prompting me to select a language (English). I push all of the buttons and nothing happens. The only button that does anything is the power button. I have taken other flip cameras apart and replaced the LCD, lens, reset the unit and reinstalled the flip software to fix them, so I'm not shy about opening up these cameras. It sounds like a hardware problem. What should I look for when I open it up?
SOURCE: Screen goes blank when capture button is pushed
Seems to be a problem with the camera and the batteries. It thinks the batteries are dead but they aren't, this is the problem I am having with my camera, I'm going to try new batteries and see if there is a Firmware upgrade.
Posted on Apr 28, 2007
  • 239 Answers
SOURCE: display wont flip over
I was Just wondering if you have both the red and the yellow power wires there may even be another power wire that runs the robotics on that unit. Just checking you probably did that though. Make sure there is none of that see threw rapping stuck in the door too. Ok I hope you get it going.
Posted on Dec 30, 2007
SOURCE: olympus 710 lens won't open
I found tilting my camer downwards towards the floor and removing the usb cover and then turning the camera on worked, I am unsure if its a faulty motor or slightly damaged lens but once it's retracted the camera works fine - this was a test I was able to repeatedly do.
Opening the camera did not display any visible faults although with the housing off it did operate better. this will unfortunatly remove some the cameras weather proofing in the way opening a splash resistant watch will mean it no longer can be used near to water, this is due to the fact these cameras are factory made, also you risk dust getting in.
I have picked up another Olympus with the same fault on eBay it would appear the 760 model also suffers from this same problem
Geoff
Posted on Dec 17, 2008
SOURCE: "Err" appear in the viewfinder and LCD display
i have a Orite Mv 3115-Real Dv Mpeg4Vga resolution 30 FPS Digital Veidio Camera. no the problem that the battery of my camera down and i sent that with my friend to bay a new for me unfortunatly he miss that on travel so i need to fins a new battery for that
i hope sir you can healp me to find one and a charger too
Posted on Feb 15, 2009
SOURCE: vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Posted on Feb 18, 2009
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
I bought a new flip video camcorder - model u2120B I cannot start it up. It keeps saying "hold red circle for setup" but nothing happens when \i press the red button. I changed out the...
first you probably did this but did you old the button for as long as it takes? ( 30 sec or less) If this does not work call fliphelp at 8882226689 open 24/7
Dec 24, 2010 | Flip Video Mino Camcorder
Flip Ultra HD - conflicting storage info
connect your flip cam to your computer.openo c drive on your computer.open flip program.look for trash file.empty it.that will restore your full 2hr record time
Jul 28, 2010 | Pure Digital Flip Video Ultra Camcorder
My flip video camera mino hd will not turn on and i pluged it onto my computer and it still didn't work. What should i do?
return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
Jul 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Just bought a flip mino HD. It wouldn't turn on,
Figured it out! Hold power button down for 10 seconds and my Flip HD works!
Jun 12, 2010 | Pure Digital Flip Mino Digital Camera
Flip Video Ultra Camcorder: After I downloaded my last videos my camera stoppe...
Remove the battery. Connect the camcorder to the computer's USB port. The computer will show the autostart menu or give a beep. Insert the battery now. Use the 'Safely Remove Hardware' option, stop the device and remove the Camcorder from the Computer. Close the battery compartment. Bingo! The device works :-)
May 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD won't turn off or on!
It's a bad, intermittent on/off switch. If you're real technical, you can take it apart and try to clean it, chances are it's dirty or the contact is slightly corroded, maybe because of humidity. If you can get a broken "as is" model off ebay, you can swap the parts out, possibly. The last and only easy "fix" to a swith problem, is to spray electric contact cleaner into them, to clean them. There are certain ways that cause less stress to the plastic parts that possibly could be susceptible to cleaner "melting", or damage. This rarely happens, but is only a warning. Now, hold the on/off switch toword the floor, and spray upward, into the switch, pressing the switch on and off as you spray. Blow compressed air into the switch as much as you can, and try to shake the excess spray solution out. Let the camera thoroughly dry (depends on the amount of fluid that got inside), but make sure it's dry, say 10 minutes or so. If the switch doesn't work properly now, the unit will have to be disassembled and further inspected, and possibly repaired or replaced. Other possibilities, such as cold solder joints, or cracked joints can cause similar symptoms, but most of the time it's the switch. Good luck, sometimes you get lucky...:-)
Apr 16, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
