My TV has a "no
  • 3,267 Answers
Digital TVs do require a fairly strong signal in order to operate properly. The fact that your set is displaying the "weak or no signal" message is proof that the incoming signal is below the required signal input level threshold.
A "rabbit ears" type of antenna would only work if you were right next to the broadcast transmitter. I assume that you have the rabbit ears fully extended and that you have tried slowly rotating it from one side to the other to see if you can get a signal lock. But seriously I doubt it.
You should check into either a set-top amplified antenna, or a larger roof or attic mounted antenna. Note: While the larger antenna should provide a much stronger (better) signal, they tend to be directional. You might have to put it on a rotator so that you can "steer" (aim) the antenna toward a particular signal. For most people, this is unrealistic due to the expense and complexity.
My recommendation is to get an amplified omni-directional set-top antenna designed to receive DTV signals. That should fix your problem.
Also Make sure you select the HDMI input using the remote control, should be a button on there called 'Source' or 'AV' or 'Input'. You may need to press it a number of times before getting to the cable box.
Good luck.
Posted on May 27, 2011
Cannot get a signal and cannot tune device.
Sorry but with this limited information we can not assist
Sep 14, 2015 | Panasonic Computers & Internet
Inputs don't work
more likely faulty tuner. have to take it to a repair shop, ask for quote , if the set is old may be cheaper to buy a new one.
Jun 26, 2015 | Vizio SV421XVT 42 in. LCD TV
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
SionEvery few days when switching on Luxor TV I get the message " No signal "
you did not mention that with which input you are using your tv. may be the input's cable is some times not connecting (bad wire) which sometime connects sometime does not. you try with replacing the wire & see if the problem is corrected.
Oct 13, 2011 | Televison & Video
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Message reads "no signal check
select the right input in your TV set, depending on what kind of device you want to use or connect to access the device.hope will help you.
May 03, 2011 | Televison & Video
When I connect my Laptop to my HD TV using a HDMI cable, I get a message saying "incompatible video signal has been received.Check the output video settings." Any ideas?
A TV will only display certain resolutions from a pc I would try to lower your pc resolution to its lowest setting and see if that clears of the problem if it does then slowly increase the setting until you get that message again then dial back one setting and that will be the highest resolution it will take. Also be aware that if you are trying to play certain games on your pc while displaying on your HDTV that signal will not always render.
Apr 10, 2011 | Computers & Internet
My Durabrand dwt1304 was hooked up to cable. I now have relocated the TV into my workshop and am attempting to hook it up to a digital converter and an antenna. Turning the TV on, I am getting a...
I suggest to go back to the menu and make sure in the connection or signal type to select antenna.. Since you had it hooked up to cable it may not have been selected to go back to antenna. Hope this helps you out.
Feb 04, 2011 | Durabrand DWT1304 13" TV
The short version: Will a 14-year-old TV work with digital-to-analog TV converter? Specifically, I have RCA Model G25342AT, built in Sept., 1994. In case yes, converter should work... Trying to connect...
The converter box should work. Getting the remote to work with the TV might be a challenge. You might have to stick with two remotes. It used to be in the old days you could plug your tv power into the remote that way you would turn the tv on with the tuner remote but I be they stop doing that.
There is website that will let you check the digital televison signals for your area. This site should help you:
http://www.tvfool.com/?option=com_wrapper&Itemid=29
Jun 29, 2008 | Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
