Question about Garden
I have a holley2300 2barrel carb ,irebuilt the carb and its adjusted to all specks but when u go to take the carb slurges on take off wats causeing it
  • Fred Kanney
    Fred Kanney Mar 24, 2012
    ajust ur float,there is a screw on one side or the other or on top of the float bowl,now make sure the car is running with the brake is on.now when u loosin the screw gas is going to come out.under the screw there is a nut take a wrench and turn it 1/4 turn to the rite that lowers the feul in ur bowl.now if its not gettin enough feul turn to the left.now keep makeing ajust mints until it rite
  • Fred Kanney
    i have one on my jeep and i do alot of rock crawling and i had the same problem
    Brigadier General:
  • 6,468 Answers
You may not have the right jets or power valve for your engine size
Posted on Mar 24, 2012
Backfires 78 sporster with a super b carb wat adjustment points or idle?
turn adjustment screw all the way down, back out 2 & 1/4 turns, then fine tune, make sure your plugs are good
Jun 08, 2014 | 1979 Harley Davidson XLH 1000 Sportster
2005 drz 125L carb hose line diagram
Might be fuel leaking from overflow. Perhaps the float valve is stuck or damaged, allowing the float bowl to overfill. Slight chance tapping on side of carb may seat the valve. If not, it will probably have to either be set, or replaced. Could possibly have some "gunk" stuck in the valve seat from the cleaning. It only takes a tiny speck of debris to hold the valve open, causing flooding. Another possible cause is that during the cleaning, the tab that adjusts the level of the float valve got bumped, changing the level.
Apr 08, 2014 | 2005 Suzuki DR-Z 125
It won't start'. I have added fresh gas and changed the spark plugs.
these can be a real pain, a small speck of dirt in the veins of the carb can cause it not to start, try blowing through it with a air line,we,ve had a few in our work shop with the same problem as you have
Jan 25, 2011 | Mantis 2-Cycle Tiller
Blower will run on choke but not in the run postion
If you haven't tampered with any adjustments (Set screw, Idle, Hi or Lo jets etc...) then most likely your carb is flooding. You either have something stuck in the needle valve passage keeping it open. (And it can be Tiny! and I mean a speck.) You can try shooting some good old "Gumout" or any other carb cleaner/ degreaser made for carbs. Try removing the gas line off the carb "Inlet" and with that hose off spray the carb cleaner into that hole liberally. Pull the throttle open and close fast as you do the "spray in".If you have compressed air? Send a little of that in there after the spray, then spray a bit more cleaner in. Let it then sit for 10 15 min loaded with cleaner. Then reconnect the gas hose, prime it up with the primer bulb, restart it, let it warm up a bit. see what happens. Oh FYI to much oil (or the wrong type)in the gas mix can sometimes cause something very similar to flooding. So make sure all is correct!
May 10, 2010 | Homelite Consumer Products MightyLite...
I HAVE A CARB PROBLEM AS I DRIVE THE HONDA A LINE ASSUMEING IS A OVER FLOW DISCHARGES I CLEANED CARB BUT CONTINUS TO FREELY SPIT OUT FUEL IM STUMPED
The float needle is stuck open. Typically the needle can get a speck of dirt or the float adjustment arm is not properly aligned. The arm should be able to close the needle at approximately 90 degrees. Remove the float bowl and look at the carb from the side and adjust the arm to seat the needle when the floats are about where they would be as if the bowl were full of fuel.
Good luck.
Mar 16, 2010 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Nov 25, 2009 | Garden
Carb leakes gas out overflow
It doesn't take much to hang the float valve open. The smallest speck of dirt or debris will cause the float valve to not shut the flow of gasoline off. After sitting for that length of time, the carburetor needs to be completely disassembled and cleaned. Use an automotive carburetor cleaner (but do not put any plastic or rubber parts in the carb cleaning solution as they will be eaten up). While you've got the carb apart, inspect the float valve. Replace it if there's a groove worn into the tapered seat. Installing an in-line fuel filter may help, too.
Nov 16, 2009 | Yamaha WR 450 F Motorcycles
How do adjust the carb on a craftsman 42cc engine ? its a walpro carb
it should have 2 screws on the crank rope side of the saw turn them all the wat in and then screw them out 1 1/2 to 2 turns is the correct setting may have to go in or out according to how the saw runs
Oct 24, 2009 | Garden
When warm idols at 2K
check the carb the cylinder gaskets if there is a leak somewhere it will want to rev really high but as for adjustment screws they will be on the throttle blade themselves and I think suzuki put them on the front of the carbs. And I think there will be only one screw, this adjusts the idle speed on both carbs. Also make sure you're running proper grade of fuel. suzuki's hate anything but premium(at least 91 octane)
Jun 22, 2009 | 1982 Suzuki GS 650 GT
I KEEP GETTING PETROL COMING OUT OF OVER FLOW PIPE ON CARB WHEN REVVING WAT IS THE CAUSE OF THIS
The floating element in the carb. is shaking as well . As you hit the throtle the shaking will lift up the floating element in the carb. house and on the overflow pipe the extra fuel will pass . Adjust the fuel level , check the floating elemnt inside of the carb. case . ( If you not sure , take your bike to the nearest garage . ) I used to play with these things for days . Avoid any damage on the carb . rubber sealant . Keep your eye on the screws ! Some of them are attached with spring as well . Peter
Apr 15, 2009 | 2000 Suzuki GSX-R 600
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
