Own this unit for one year now and it is just starting to leak from the back of the unit. What can I do?
Leak water?
That is what it is supposed to do
The water will drain outside
Posted on May 27, 2011
Popping/clicking noise
for window type ac, it must be positioned on level, to avoid flexing it's case.
Jun 04, 2013 | Haier Heating & Cooling
Unit is leaking underneath and onto my carpet....
Check your manufacturers warranty to establish warranty period and also Sam's customer service to see if they will support you. Hose and
connector need to be replaced to eliminate moisture. This can breed
mold if not properly addressed.
Aug 04, 2009 | GE APH10AA Air Conditioner
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Water leaking out freezer door--unit is still making ice
There is a shroud at the back of the freeezer. (Mine was a GE) but under the shroud is the evaporator coils and also a heating element to defrost the coils during the defrost cycles. Mine had the gutter underneath misaligned and the water went into the freezer and froze instead of going down the drain. I thought it was a ice maker leak until we found that. The weird thing is we had the refrigerator for about 6 years before it started leaking like that.
It has worked fine for about a year since that "fix"
Jan 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite 110.2949 water leak from center front of unit
Check your pump. The pump is located on the end of the motor. You can tip the machine back and pull the pump off to check it. After you take the pump off. Check to see if there is a water stain where the shaft of the motor goes through the pump. If so you pump is leaking.
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
2 year old kenmore elite water leaking in freezer area
Does this happen when unit is in a defrost?? If so, sounds like the drain line is clogged.The hose and pan are located under the unit.You can access this by removing the cardboard back cover.Find the drain line tube.I'm sure the drain opening at the evaporater is iced over.You will have to unplug the unit and keep the doors open to defrost.(Removing product in unit will decrease defrost time.) Maybe an hour to an hour and a half.Could be longer!! Try using a wet/dry vac to clear.
Nov 25, 2007 | Kenmore 53642 / 53644 Side by Side...
1 1/2 years old 5 tons leaking yellow rusty water
Most likely yours has a scroll compressor which are notorious for being quite loud on start they will start for years, just a liitle noisy. Is the water from the pvc drain or from the base of the outdoor unit??
Oct 02, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
