Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
I own a Westinghouse LTV-32W1 and I am trying to hook Comcast basic cable up to it through the coaxial input. But, the only coaxial input is labeled ANTENNA.. I had the TV scan channels from cable AND antenna and it only found one channel. Analog at that. But, it doesn't do anything. How do I run basic cable to this TV? I thought, because it was HD-ready that I wouldn't need a box. :/
  • 1 more comment
  • misterv936 May 27, 2011
    I do not have a manual. I bought this TV used off of Craigslist.
    No, I do not. I bought this tv used.
    No, I do not. I bought this TV used off craigslist. I don't know much about it at all..
  • 8,197 Answers
If you are trying to hook it up with cable make sure that the Tv is on cable mode. You will not need to scan for channels if you are using cable. If you scan for channels you are telling the Tv that you are going to use an antenna. Just put the TV on cable mode then close all windows and try to watch the TV. If that does not work that means that you will need a cable box. If you are using a cable box set the Tv to cable and turn the TV to channel 3 and you will use the cable box to change the channels.
Do you have the manual for this TV if not please let me know and I can get you one.
Posted on May 27, 2011
Audio solutions lcd
Hold down power button for 15 seconds when powering on to reset HDMI inputs
Sep 30, 2013 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Where is the optical input
It may not have one---no owner/instruction manual?
Google the model number of the set with "manual"
Mar 26, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I am currently through the comcast service and i plugged my cable cord directly into the tv and i am not getting any pictures just sound. can you please help
Please clarify as to what kind of wiring setup you are using from the Comcast cable box to the TV. Is it composite video cable (yellow RCA plug) with Red and White RCA plug for audio, or HDMI cable, or Coaxial RF cable with TV set to Channel 3 or 4?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span><br />
Aug 27, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv turns off and dont want to turn on again
check outlet power by connect other device, check power cord if OK check then unplug tv and open the back cover and check power filter fuse power filter is the one that you hooked power cord if OK check power supply board fuses if OK check the power supply board for bad blown components .good luck
Apr 29, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Comcast Causing Purple/Green Hum Bars
this is normally caused by voltage on the coaxial cable which simply can be solve by a surge protector with a cable in and out.. but this is just a way to passify the issue. More than likely there is a bad ground either in your house or on the comcast line
May 06, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
200 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
