Question about Smeg Dishwashers
I have a smeg st663 that has the delicate and normal wash buttons illuminated and the intensive button flashing after the last wash. Some water failed to drain and I can,t reset it. Any suggestions.
  • Smeg Master
  • 19,396 Answers
Hi.
Try first to reset the error follow the procedures below.
1:
  • Hold down program selection button for up to ten seconds
  • Close the door.
  • After approximately 1 minute the dishwasher will advance to the end
    of cycle.
  • Turn off power from main circuit breaker.
  • Dry water inside the dishwasher.
  • Clean the filter unit (see Manual here, page 26 )
  • Apply power back.
3) If that does not work, please try the following procedure, it should enter diagnostic mode and reset the error.
  • Switch off the appliance
  • Turn the dishwasher back on.
  • Before any of the lights coming on press immediately the program button. Program button must be pressed 4 times within 4 seconds.
  • The two last program lights (normal and intensive) should start flashing.
  • Press again the program button once.
  • The Normal light will turn off.
  • The last light will keep flashing.
  • Switch off the appliance.
  • Wait 10 seconds.
  • Switch the appliance back-on.
If error is still there, then the problem is water pump malfunction. This will turn on second and third light from the left (light wash and regular wash)
The appliance cannot pump out the water. Check that the drain hose is not kinked or crushed and that the siphon and filter are not fouled. Check height of the drain hose at the back. Clean the drain well and filter located on the bottom panel of the machine. If the problem persists, contact the after- sales service. The pump must be accessed, freeing the hose connected to the pump from blockage, and testing the pump motor.
Note if lights are instead first (soak) and third (regular), then the problem is water inlet. In that case check pressure from the house, inlet hose. If that does not fix the problem, then the inlet valve and water level switch must be tested.
If lights are Delicate and Normal (the one with glasses and the one with dishes), then the problem is drain.
Regards.
Ginko
Posted on May 28, 2011
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
Water hasn't drained and combination of lights notin troubleshoot
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 29, 2010 | Smeg STX2 Dishwashers
Smeg ST663 gets stuck onwash cycle
I have the same problem. If anyone has an answer I would be most greatfull.
Feb 11, 2010 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Smeg Dishwasher
replace the timer/control board
May 26, 2008 | Dishwashers
Dishwashers Logo
213 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
