Question about Maytag Washing Machines
An F6 E1 error code - Maytag Washing Machines
3 Suggested Answers
livewire874
  • 618 Answers
SOURCE: We just got a brand new MayTag Modle # MHWE200XW00
It is a communication error between the CCU and the MCU. It could be just a poor or loose connection or either the motor control or computer control. try unplugging it for 5 min then plugging it in again.
Posted on Oct 27, 2010
SOURCE: Wash cycle won't start, gives F6 E1 error code.
We have had two brand new machines. First one worked for 4 weekends and quit. Second brand new one just delivered does not work at all. Solution: I will never buy whirlpool again!!!!!
Posted on Feb 19, 2011
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Maytag front load washer mod mhwe251yg00 cde e1-f6
Serial communication error you have two computers one up top the CCU and one down below the MCU it's saying the two are not talking to each other the tech sheet has you go thru about 20 steps to basically come to the same conclusion it's either one or the other which I could help more but I run into the same problem in the field. Most times it's a failed CCU
Jan 20, 2014 | Maytag Washing Machines
Model number wfw9250ww error code e1 and f6
How to fix a error code of E2F3 on a whirlpool duet model # wfw9250ww00
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag 2000 series shows error code f6 e1. How can I fix?
Before spending much time and possible unnecessary work, the E1-F6 code may be nothing more than your bottom cover plate is not in place or missing. Recently was servicing a Maytag 2000 series wash and during the inspecting of the cycles it quit and flashed those codes. I had been testing it WITHOUT the bottom cover plate on. When I went to install it back on the code disappeared. Problem simply solved.
Mar 28, 2012 | Maytag MHWE200XW Washer
Screen flshes e1 f6
E1 is not an error code on this model. Check to make sure its E1
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
If you have anymore questions or need further assistance please feel free to comment me back.
Jul 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
653 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
