Question about Keurig Elite B40 Coffee Maker
Power light does not come on.does not do anything.
  • Keurig Master
  • 43,501 Answers
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 05, 2011
No power on LG TV
Could be power supply failure
Oct 16, 2016 | LG Televison & Video
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Jul 04, 2010 | Riccar 8955 Upright Vacuum
I have a 1977 Mercury Grand Marquis the turn signals, brake lights, and turning lights do not work. The running lights and hazard lights do work. I checked the bulbs and the relay can for the turn signals...
Turn signal switch (also brake light canceling switch) most likely bad or bad wire to it or from it. Check, with key on run, for power into switch. Turn switch on, check for power out. No power out switch bad. Power out, trace to rear tailight harness for broken wire.
Jun 30, 2010 | 1977 Mercury Grand Marquis
With key turned on there is no power to anything. No lights no anything.
first check your fuse, if it looks good get a test light and double check it. A simple test light is the first thing i go for when i'm hunting down elec. problems.
Start at switch got power in? yes got power out? if not why not? if so work you way down till your lights won't like it up. If you need more help please feel free to let me know.
Happy Hunting
Mark
C.C. Motorsports
Feb 14, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Samsung SyncMaster 213T monitor after power failure the on light is on but the monitor will not do anything, no menu or anything just the black screen with the on light on.
This may be the power supply board.
the rectifier chip or diodes may have been fried by a surge of power when the power came back on.
If the monitor was not plug into a surge protector this may have damaged the power regulator the main board of the the monitor. The primary side of the board should be tested for faulty components.
Dec 02, 2009 | Computers & Internet
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
I just bought the NC6000 second hand and it wont do anything. I have opened the lid and press the 'on' button, is there anything else I should do?
Check for a button on the battery pack on the bottom. Pressing it should light up the amount of battery power available. A defective battery could be giving you issues. I would also try an alternate power pack. Most power packs have a light on them. If it is not lighting up chances are it's the power pack.
May 01, 2009 | HP Compaq nc6000 Notebook
Keurig Elite B40 Coffee Maker Logo
55 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
