Question about Remington Precision HC-815 Hair Trimmer
I have a remington precision model HC-815 I took them apart to clean them and when I tried to put them back together the blade kept falling out of it why is this happening.
EwingElect
  • 276 Answers
SOURCE: Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Posted on Apr 08, 2009
EwingElect
  • 276 Answers
SOURCE: Replacement blades?
I'm not at work so can't confirm if there's blacdes for the HC920 but the majority of Remington Hair Clippers do have replacement blades.
Go to http://www.remington-products.com/country/index.htm to slect your country.
Authorised Remington Service Centers can be found at http://www.remington-products.com/consumer/asd.htm
Posted on Apr 11, 2009
  • 3 Answers
SOURCE: took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Posted on Jun 20, 2009
brector3
  • 1610 Answers
SOURCE: The clipper blade adjustment on my Remington Hair
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Posted on Jan 26, 2010
Testimonial: "Thanks "
SOURCE: Remington HC-921 Mens Clipper Kit Pulling hair not cutting
no but I can't wait until someone does- having same problem. They worked fine then didn't
Posted on Apr 26, 2010
Where can i buy new blades?
The Remington website doesn't offer spare parts for this model probably due to the price.
Available on Amazon for 20 pounds as a complete unit.
Remington H C 8017 Hair Clipper
May 12, 2014 | Remington Precision HC-8017 Hair Trimmer
I have a Remington Model HC-912A hair clippers and need to find a 1.8 inch attachment. Where do I find one?
The Remington Model HC-912A has adjustable blade with a lever on the side, you can use the Wahl attachment comb. You can this this at
Manny's Sharpening
Jun 11, 2012 | Remington Precision HC-8017 Hair Trimmer
I have no problem with the trimmer,I am trying to get an attachment that did not come with it when I bought it.I would like to purchase a 3/4"spacer,I have1",1/2",and 1/4"
Looks like this model is a older and neither the Remington company and any of their retailers carry parts for this trimmer. Perhaps you can look on ebay or bizrate for a similar item that comes with this spacer.
Good Luck!
Apr 13, 2011 | Remington Precision HC-815 Hair Trimmer
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
May 04, 2017 | Remington Precision HC-8017 Hair Trimmer
The clipper blade adjustment on my Remington Hair Clipper, model HC-8017 (a black plastic adjustment arm) broke. Is it possible to get a replacement part?
Jan 25, 2010 | Remington Precision HC-8017 Hair Trimmer
I have a remington precision hc-912 hair-trimmer. My 1/4 inch guard broke and I don't know where I can get a new one.
Use a precision screwdriver and pry the clip up. It is spring metal and will snap back into position upon reassembly. You will have to solder the battery in place. Works on all microscreen shavers supermesh and XLR.
Aug 31, 2009 | Remington Precision HC-815 Hair Trimmer
Blades pull hair when cutting
Just make sure the blades are aligned precisely and make sure it is well oiled. It should be oiled after every use. I use WD40
Jul 17, 2009 | Remington HC-600 Hair Trimmer
How do I put my shaver back together after I replaced the blades?
For Remington clippers, the smaller blade has a groove which matches a beveled edge on the trimmer body. Line it up, align the larger blade to its screw holes, insert and fasten screws until tight, and you're good to go. Oh yeah, and try to center the small blade.
Mar 12, 2009 | Health & Beauty
I also need a new 1/8" and 3/4" guards.
The link below is your only source. Find out from them if there are any authorized dealers in your area. Most likely you can buy spare parts directly from them.
http://www.remington.com/support/parts/
Jerry G.
Jun 02, 2008 | Remington Precision HC-815 Hair Trimmer
Remington Precision HC-815 Hair Trimmer Logo
66 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
