Question about Dryers
Wireless ceiling fan
My ceiling fan is located on the ceiling in the middle of my cathederal ceilinged greatroom. A cord is attached to the fan and swags over and plugs into a plug at the top of the wall about 5 feet away from the fan. I can use the switch which is lower on the wall to turn the fan on/off. I don't want the cord showing that connects the fan to the plug and can't easlily recess it into the ceiling.
Is there a device(s) that can be installed into both the fan & plug (wireless transmitter?) that will enable me to eliminate the hanging (swagged) cord and operate the fan from the switch on the wall? I am ready to replace the ceiling fan and need to know what to buy to enable this.
  • 284 Answers
There are remote controlled fan out on the market.
there are also devices the make it remote, but the cord is for power so i dont think you can hide the wires to much without going thru the ceiling.
if you have no access of the cieling then the wire must be there for powering of the fan run along the wall, try stapling the wire to the cieling like around the egdes of the ceiling then perhap painting the wire the same color of the ceiling.
you do not have much option to work with.
you have to make sure you buy the right remote controll
but it still need power.
there a site for remote controls for fan or just buy a new fan all together. im sure they put the plug there for a reason because if you use the fan alot they do go bad.
Good luck
Posted on Aug 16, 2008
The transmitter is the piece you hold in your hand, the reciever is the part that fits inside the ceiling fan. It usually goes inside where a lamp attaches to the bottom of the fan.
Aug 01, 2014 | Hunter Sontera 52" Ceiling Fan with...
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
We purchased a house that is more than 10 years old. The ceiling fan w/light does not turn on with the wireless remote that is attached to the wall and there is not other switch but this one to turn it on....
You need to know if there is power to the fixture. If there is , then you might need to replace the receiver. It should be under the canopy where the power is connected for the fan.
Sep 01, 2011 | Hunter Ceiling Fan Light Remote Control
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
I wish to install a ceiling fan in my bedroom. The roughing is already installed in my ceiling. The problem is the electrical box is recessed a half inch into the ceiling. Could I mount the ceiling fan if...
a celing fan should only be mounted on a box rated for a ceiling fan. This is a NEC code requirement. You could remove your existing box, and install a new box rated for a ceiling fan. You install the adjustable cross bar, and then attach the box to it. It also has stronger threaded inserts for the fan attaching bolts. Better than having a fan flying through the room.
Jul 25, 2010 | Lamson Electrical Box Extender
Pull cord broke off ceoling fan
The cord attaches to the switch that controls the lights. It looks similar to the one that controls the fan. You can get replacements at home improvement stores that sell fans. You can get a manual from Hampton Bay's web site.
Sep 03, 2017 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Ceiling fan with mind of its own
Sounds like you're getting interferrence with the wireless control module. You can remove the shroud at the fan and try another setting on the remote control module. Just be sure to set the wireless hand-held control to the same settings in order for it to operate properly.
Please refer to your owners manual for the fan and the wireless controller for any questions on how to set them to work together. You may have to try a couple of different settings until you get one that isn't
affected by the interferrence it is presently receiving from another ireless source.
Those sources could be a garage door opener, wireless doorbell, TV or other remote control. Cell phones, walkie talkies, and so on. Almost anything that produces a radio signal, could be the cause of the problem.
Hope you found this very helpful and best regards!
Aug 06, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
The fan blades do not turn but the fan motor can
speed switch is no good, the one attached to the pull cord. replace
Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay Ceiling Fan
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 01, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to convert ceiling fan into wireless ceiling fan
Can a wireless remote control kit be added to a flush mount ceiling fan? Is there enough room for the receiver?
Jul 21, 2008 | Dryers
Dryers Logo
781 people viewed this question
Top Dryers Experts
