Question about Microwave Ovens
Power switch on my sunbeam espresso EM2300 has failed, want to know how to open the unit to replace switch, it is far from obvious how it comes apart, a service type manual would help if you can source one
2 Suggested Answers
mastermaid
  • 502 Answers
SOURCE: sunbeam urban series espresso model
Here is the manual.
Posted on Jan 01, 2012
Microwave quit when door was open
yes,unplug the unit,take the screws out of the side and back lift the cabinet up and off and you will see a fuse right on top replace it.hope this helps
May 19, 2014 | Sunbeam Microwave Ovens
Hi. my micromark MM60106 oven seems to be dead ,no red light, no heat ,no fan. power is getting to the switch but nothing works, do I need a new selector switch
Try using the VOM
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Apr 02, 2013 | Microwave Ovens
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
There is little or no heating effect from the microwave
In all likelihood the mangnetron has failed, or perhaps even the Power Supply.
Feb 17, 2010 | Sunbeam SBM7500W Microwave Oven
NO POWER
1 the obvious question.... have you tried a known working outlet. 2. Most likely the internal fuse has failed and must be replaced. You can access this fuse by removing 4 side panel screws, (2 on each side) and 6 rear chassis cover screws. BEFORE you start unplug the unit. Remove the 10 screws. Standing behind the unit, then lift the top cover slightly and pull toward you. the side guide tabs wil unlock and the cover will come free. Once the chassis open aviod the large capacitor as it can still ruin your day. Follow the power cord until you see the fuse block. Remove the fuse... obtain an EQUAL value replacement and install the new fuse. reinstall the cover making sure the side guide tabs interlock on the front sides of the chassis. Plug the unit in and see if you have any signs of power.... I.e light on with door open or control panel dispaly lights up. If you have visible signs of power places a coffee cup filled with water inside the microwave and see it it heats up. If it starts and then all the power goes off again you probably have a bad diode. If it works fine then your in luck.
Jan 06, 2010 | Sharp Microwave Ovens
Sunbeam 700 watt micro shut off while in use now nothing comes on
it is problem power supply or panalboard unite,If you are not a technician,please go to a service center.
Dec 06, 2009 | Sunbeam SMW777 Microwave Oven
Sunbeam Mic.Wav. no display... tray runs...
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
If you or someone you know decide to look into it, see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If you only need a switch, you can order a universal type here for $5 postpaid.
Nov 27, 2009 | Sunbeam Microwave Ovens
Keypad has quit working.
hi there,
for clarification request; may I know what exactly the model that you have. did you noticed / check if the unit has a power coming into it. first check the elec wire, plug the unit unit on a different outlet.
Thnks
Jun 15, 2009 | Sunbeam Microwave Ovens
No power....no display...no cooking..no workee
Hi, Your dead on the money, this or called thermal shoutdown switches, when the unit get's to hot this will protect it again's over heating, on this peace there will be marking , this marking will be the temp. of shoutdown and other number for part #.
Go on googles and try the part # you will see it come up and just replace it. If you have another scrape micro you can take out the other and used it there mostlicly the same thing
Hope this Help
What About Bob
Feb 10, 2008 | Sanyo EM-Z2001S Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
