Question about Kenmore Grilling
How to replace the gas collector box kenmore grill 141 166400? I purchased replacement before reading that I have to "drill out the original nuts?
  • 4 Answers
SOURCE: Kenmore Elite 17680 gas grill
I had a local barbeque grill retailer ( a fireplace and barbeque store which did repairs) install a new one for me. I didn't want to mess with the venturi tubes and the exact length of the openings so it would work. I am glad I did as it works perfectly.
Posted on Jun 19, 2008
brnspncr
  • 67 Answers
SOURCE: Replacing ignitor battery
Has it got a battery or has it got a Pitzo crystal? They eventually wear out, you may need to replace the ignitor button unit.
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
Posted on Sep 08, 2009
  • 43 Answers
SOURCE: I have a Kenmore natural gas grill, model #
owners manual can be gotten through the internet- Sears.com find parts,type in model# of item, select manual sounds like valves are clogged- propaine and natural gasses are dirty gasses-no filter, it comes up out of ground,through dirty pipes, all the way to peoples homes- and thats why they have to replace valves on hot water tanks/furnuces........
Posted on Jan 07, 2010
  • 43 Answers
SOURCE: Kenmore Gas Grill will turn off after three burners are on.
replace the gas regulator the hose connector to propaine tank
Posted on Jan 08, 2010
I have a Kenmore model 141.16681 and gas now leaks at the regulator valve
check regulator to see that the rubber seal in the tank coupling
is still good if this has perished or fallen out this maybe the cause of
gas at this point.
best purchase a new regulator if it seems faulty, this part is your life saver, and after 8 years good service could well need replacement.
I hope this was useful.
Sep 01, 2012 | Kenmore Elite 644 sq. in. Cooking Area Gas...
I have a Weber Silver B grill that I purchased 12 years ago.I would like to convert it from propane to Natural Gas. I have been told I cant! Is this true? If not, where can I get a conversion kit? Thanks!
Weber stopped selling conversion kits due to some legal action in 2008. There are no longer kits available. What you would have to do to covert it is order a replacement gas valve for the NG version of your grill just to get the orifices. Then you have to replace the LP regulator with a NG regulator. Typically most NG grills do NOT have a regulator but local building codes will require a NG regulator and a different gas line hose.
Conversion of a BBQ gas valve to NG is a matter of drilling out the orifice to a larger hole in an LP orifice.
You will not find anyone that will perform this conversion for you due to legal liabilites.
If you want to convert it... you will either have to order the whole gas control valve for NG or drill out the orifices yourself in your current gas valve hoping your got the orifice hole size correct when you drilled it. Mind you all liability for doing this lies solely with you.
This site has all weber parts:
http://www.clagrills.com/allgrillparts/weber/weber-models.htm
http://www.clagrills.com/gasgrillparts/weber/weber-gas-grill-parts-home.htm
Thanks for choosing FixYa,
Kelly
Apr 29, 2011 | Weber Genesis Silver B Grill
Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
May 15, 2010 | Kenmore Grilling
Gas is not getting to the burners on my Sears Kenmore gas grill.
check if regulator fully screwed to tank, turn on tank,then last burner,should hear/smell gas. if not replace regulator
Jun 25, 2009 | Kenmore 16225 Grill
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Elite 17680 gas grill needs a new burner. I purchased the burner, but do not know how to install it. Can this be done as "do it yourself" or does it require a serviceman?
Apr 25, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Kenmore Master Flame Grill
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
Mar 16, 2008 | Kenmore 16225 Grill
Jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Mar 12, 2008 | Grilling
Igniters for gas grill
Go to your nearest Vermont Casting dealer and they will directed you on the part number and the dealer you need to go through.
If it is the collector box you are looking for part number
# AN000103
Aug 08, 2007 | Cfm 8000N Grill
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Grilling Logo
128 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
