Re: Does GE make the Frigidaire brand washing machine?...
Hello, welcome to FixYa. The GE frontloads of several years ago where indeed made by Figidaire ( not the other way around) though GE now make their own as do Frigidaire/Electrolux and no longer have anything in common. The GE that had been built by Frigidaire used identical pumps, you'll just need to provide a model number of the unit in question and I can tell what pump it uses...and what washers it will work in. Thanks for choosing FixYa today.
Regards, Macmarkus :)
well for starter , please make description of your utility machine , brand name , load capacity , type of load ( i.e: Frigidar affinity , front load , ultra load capacity ( meaning over 3 qf ) per load . and then we may can help you , you can also use the internet to log on to your washing machine brand name manufacturer , in example if you have Frigidaire like i do then the link to that machine is this address : http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
this is the product support link for all Frigidaire .
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
GE washers are a decent machine. These days I don't think there is one brand better than another. All are mass produced and even the higher priced ones are no better than a cheaper one, the higher price is just for options. Stay with one of the major brands that have been around a long time and stay away from ones you never heard of. With names like GE, Whirlpool, or Frigidaire you will at least be able to get parts and service if needed.
Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
Blocked Pump
One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
Drain Hose
If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
Oversudsing
If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
Pressure Switch or Control Boar
The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
You'll need to get a good look underneath to see where the leak is
Most times it's the pump that leaks
Available from Sears $107.63 Item # 43 on this diagram:
based on info provided your ge would be a frigidaire made machine, only filter is at drain pump. to access remove lower front access panel (screws on bottom) pump sits in middle of machine, locate large rubber hose connecting to tub, loosen clamp and pull off. inside is plastic strainer cup, empty and replace. make sure nothing went past to pump, reassemble.
My GE washer instructions said to leave the door open or mold could form inside. IMO (and many sales reps I spoke with) Frigidaire is not a good brand. And being one of the cheaper brands, you get what you pay for. Good luck with your law suit.
Own a Kenmore? Department store brands can be a pain as it is difficult to figure out which manufacture has made your product. This link here should help to find out which manufacture has made your Kenmore Appliance.
