Question about Samson ZOOM G1x Guitar Effects Pedal
When turned on,the G1 is on display and it hangs and won't go to bank or by pass anymore
  • Manoj Raghunathan Dec 29, 2012
    I am facing the same problem. My display is stuck in patch d5. There is no sound output.:( . IS there a solution?? Please help
Dude we have same problem..our G1 is history......god of rock..help us...!
Posted on Jul 12, 2011
Same problem bro with my G1XN .... plz help!!!
Posted on Oct 05, 2011
  • 3 Answers
Same problem here! cant find any solution.. sometimes it works and sometimes not so annoying!
Posted on Feb 20, 2012
  • Siddartha gazmer
    Siddartha gazmer May 13, 2014
    Yes my beloved zoom g1x is history, nd its so bad we can't get help from zoom cop.
My zoom g1x theres no sound.all power are working lcd light are on.but the sound cannot come out.can any one help me..
What letters / numbers that appears on the screen?
If the display is normal, and you can switch to other banks, and can edit each bank, then the problem of no sound, is at the pre-amp IC input, output amp, or CODEC converter.
This is the overall image of G1X inside.zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-0.jpg Next, we zoom-in the middle of picture above.
See the next picture.
IC2 (left) is input pre-amp IC (NJM2100).
IC4 (middle) is the CODEC IC (WM8734).
IC5 (right) is the IC output (NJU7082).zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-1.jpg
Test whether the input IC is working normally, turn ON G1X, plug the guitar, go to BYPASS/TUNER menu. When the TUNER function could work, certainly input IC is not damaged.
Means only two possibilities, namely CODEC and output IC. That is not easily tested, except in specific ways.
May also, there are problems in the input / output socket.
Turn ON G1X. Try the following (see figure below):
  • Test the output socket. Touch pin output socket (right red arrow) with finger / screwdriver / whatever. If sound is heard in the amplifier, the output socket is normal.
  • Test the input socket, Same as above. (left red arrow). (if this happen in this point, problem is clear).
NOTES:
If lcd light are on (as you say), but appearing G1 or d5 or bt, and the system are hang / frozen, this is a different issue to the one described above,and dealt with in different ways too.
References IC datasheet:
NJM2100.
http://www.njr.com/semicon/PDF/NJM2100_E.pdf
NJU7082
http://www.datasheetarchive.com/dlmain/Datasheets-22/DSA-439015.pdf
WM8734 http://www.cirrus.com/en/pubs/proDatasheet/WM8734_v4.4.pdf
Sep 10, 2015 | Zoom Music
Suzuki ss-100 piano keys stick, won't play
I had an issue with my Suzuki GP-3 and I did a research and found a company called VMI Electronics (619)244-0006 they found me a technician in my area also there is a repair kit called Key Mod that fixes issues with the keys hanging low, here is the link to order it on ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
Mar 28, 2013 | Music
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
My g1x zoom pedal turns on but no sound will come out ? HELLLP ASAP.
did you check the instrument cables? could be one or more of them is shorting
Oct 19, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
The CD input on my Ampeg BA 115 works, but the 0db and -15db inputs don't. This happened immediately after using the CD input. Quick fix, or repair shop? Thanks.
Sounds like a repair shop job to me. Inputs on a amp have resistance thus there must be a issue inside hence 0DB to 15DB if you go higher well that input thus would not work anymore.
Repair shop would be your best bet for this amplifier. Quick Fix would be unplug it and plug it back in and praying it resets but that won't happen.
hope this was of some help, if not I am sure others will chime in with there 0.2 cents.
Regards
Rulds2008
Jun 15, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
Blue bank has a led that is bad when using the lights for more than 30 minutes the blue color goes out. i open the unit and just touch the blue led pack in the back on the solder led part and they turn on...
I have seen bad solder of the pins of the connector on the board with the LED's. Reflow the solder and verify there are no solder bridges. ALSO verify that the circuit traces near these pins have not been lifted or broken.
Apr 29, 2011 | Chauvet Dj Bank 140led Dj Club Effect...
What kind of power source/adapter do I use for my Casio tone bank
Take a close look at where the power source adapter plugs in, there should be something written which will indicate the voltage requirements, write them down, for example it might indicate +plus or minus 12 volts DC at 400 Milliamps. Take the info you write down to Radio Shack and they should be able to sell you a universal power adapter that will work. You should have a power on-off switch some where on the unit.
Mar 22, 2009 | Music
Samson ZOOM G1x Guitar Effects Pedal Logo
520 people viewed this question
Top Samson Music Experts
Matthew Spark
Matthew Spark
Michial Gueffroy
Vito Vacirca Jr.
Are you a Samson Music Expert? Answer questions, earn points and help others
