Question about Bosch Dishwashers
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
    President:
  • 1,140 Answers
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
Posted on May 27, 2011
  • 1 more comment
  • DILLIGAF
    DILLIGAF May 27, 2011
    Sorry - Fixya junked my formatting (again) and deleted an essential character (<) from step 6. Here are the instructions again . . .
    2. Open the door
    6. Press < repeatedly until none of the LEDs are flashing.
    0 = Silent
    1 = Volume level 1
    2 = Volume level 2
    3 = Volume level 3
    8. Close the door
  • DILLIGAF
    Now it's decided to write everything in bold text! One more try . . .
    2. Open the door
    0 = Silent
    1 = Volume level 1
    2 = Volume level 2
    3 = Volume level 3
    8. Close the door
  • DILLIGAF
    **** it.
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Beeping won't stop at end of cycle
Our Bosch does the same thing, we just open the door shut of the power and close the door again so the heat can sanitize the dishes. I don't recall if there is an alert off button though.
Jan 08, 2014 | Bosch SHU9926UC Built-in Dishwasher
Bosch dishwasher runs through cycle too quickly
Steve, did you find an answer to this problem? Having the same problem
Jun 18, 2012 | Bosch SHX4AP05UC Dishwasher
Related Topics: turn beep off beep turn
Hello Craig,
You can use Affersh dishwasher cleaner (link here) http://www.affresh.com/our_products/affresh_dishwasher_disposal_cleaner and to achive "Super hot" wash you can reset your hot water heater to a super high setting and the run a few cycles of the dishwasher....once done be sure to reset the hot water heater to the usual setting...also a very effective cleaner in the dishwasher is white vinegar ,try that along with setting the water heater higher
Good luck,
thanks for using Fixya.com
GENE
Nov 25, 2011 | Bosch SHX4AP05UC Dishwasher
Bosch SHX4AP05UC Very LOUD!
This doesn't add up to what other owners say. Have yo contacted Bosch? Also, your output line may be entering your drain system in the wrong place causing the noise for that issue. Good luck. I am looking at the same machine for purchase......
Dec 16, 2009 | Bosch Dishwashers
I have a bosch dishwasher model # I believe is SHX4AP05UC it keeps tripping my braker in the middle of washing wont complete a cycle any suggestions?
Adam, in order to help you, you must provide me with more info. What size breaker is tripping. What does the maufactor's manual reads about what size circuit it must be plugged into. If your house is a little old you probably have a 10 amp breaker that is tripping. If so than the manufaturer states theat it is recomamded to place it onto a 20 amp breaker. Only switch out the 10 map breaker to a 20 amp breaker if your the wire from the breaker is a 12 gauge wire.
Do not put a 20 amp breaker onto a 14 guage wire because it will most likely melt the insulation due to heat whichwill expose the bare copper wire which could lead to burning your house down.
Dec 02, 2009 | Bosch Dishwashers
Dishwasher doesnot drain
Once you ensure that the drain lines are clear, this usually means that the drain pump is stuck, clogged or faulty.
Try first unplugging power cord for ten minutes.
If this does not help, the pump is clogged or defective.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
1,485 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
