Question about Ovens
Whirlpool Oven Model RBS245PDS18. Used "self clean" & elements will not heat now. Pulled elements and both ohm good. Wondering how to test the temp probe part # 9759243.
Thermostat
PART NUMBER: 9759243 part #37 at sears parts direct diagram has failed.
Located on rear of oven, so oven must be pulled out to access. Has happened twice to me after setting oven to "self-clean".
Posted on Jan 29, 2013
3 Suggested Answers
Powerman
  • 68 Answers
SOURCE: GE JTP56 Double Oven
Hello there,
This may be related to the F7 problem even if you are not getting an error message. Go to my web site at the following link:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
Please let me know if this works for you. I have sent my fix to over 1300 folks.
Good Luck,
Powerman
Posted on Oct 21, 2007
localwonder
  • 6784 Answers
SOURCE: I have Whirlpool oven Model # RB220PXK (almost 30
HI. You can Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
NOTE- The element may have small holes and bubbles on the coils as well. This is a sign of a burned out element. Test the element connectors as well.
Posted on Oct 12, 2009
Where do I locate the fuses that controls the oven heating.
Hello Pat;
My name is Peter. I am a retired field service appliance technician.
When you go into self cleaning both of your burner element peak at there max temperature, well above 500 degrees F.
1.) Oven Element - Over time the elements will fail. Turn the upper element on. Inspect for sparking where there may be a crack in the element. Turn the upper element off, inspect for any cracks.
If there are no cracks then you lower element is fine.
2.) Each of your ovens have a independent thermocouple. Both may have failed due to the extreme heat. Oven thermocouples will fail on older units.
3.) Lets go to the source. You have what is called a infinite switch in your oven. This switch controls your oven temperature. If this switch fails then your oven will not work.
Ok, lets assume you or a friend are good with tools. With a multi-meter set to the lowest Ohms, In the back of your oven there is a sheet metal cover. Remover the cover, disconnect the two contacts on each thermocouple, and Ohm them out. (Power Off at your breaker box first) You should get a reading of '0' Ohms, anything else the thermal couples are bad.
But, I tend to believe, You have a bad infinity switch. You can also Ohm this out as above with a reading of '0' Ohms.
This component is about $35.00 USD.
If I were still working for Sears Home Services I would charge you $350.00- $450.00 for this service call. Send me your model number and let me see what you have. goodwinpeg@aol.com.
Feb 24, 2015 | Ovens
What should an oven temp sensor's ohm reading be if it's at room temperature and not faulty? Whirlpool 30" electric range, model number WFE361LVD Bake element and broil element do not heat...
The oven sensor should be between 1000-1200 ohm's at room temperature or roughly 1080 ohm's. I would place the Tech Sheet here but Whirlpool will not allow me to post their manuals or Tech Sheets. You are welcome to the Tech Sheet HERE I hope this helps Thanks, Sea Breeze
Oct 22, 2011 | Ovens
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Upper oven will not heat up in any mode. "Pre Heat" and "On" come on for a few seconds, then go off. I checked the elements, all between 15 and 30 ohms. Every now and them it will...
Hi n664v,
This sounds to me like a Thermostat problem. If it is an electronic version Oven, then it will be the Sensor or PC Board Module controlling temperature. Please let me know what Make and Model your Oven is, so I can better assist you.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Aug 17, 2011 | Ovens
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I used the self cleaning function and now the over wont work. The lights work, but no heat is produced. I get no error messages, any ideas?
might want to check if element has continuity with light-wire-battery technique or VOM (volt ohm meter)...unplugged and element out... then while element is out can plug back in and use VOM to check element receptacle for 220v AC (to see if power coming to element (good to check also since continuity check can be fooled by a break in the nichrome wire within the element where the ends of the break only retract to make a gap when main current is applied)
........If no voltage at recepticle then between their and control switch/temperature selector.
...the full blast current and heat of self cleaning, could have completed the ready to fail point/switch/etc
Aug 09, 2009 | Whirlpool RBS305PR Electric Single Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Our oven's heating elements will not come on althought the display seems to work correctly.
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. Catriver..post back.
Dec 18, 2006 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
