ZyXEL Prestige 653HW1-11 I want to configure this ADSL router for my PC use to access internet through its wired LAN port (it has 4 LAN ports) and wireless port, I don't know how to set it up for both wired and wireless access. thank you.
SkinWill
  • 148 Answers
SOURCE: Siements 5890 router
When you say HQ is that outside on the wan port trying to ping the Lan port?
Sometimes the router itself will respond to a ping but will not pass ping requests thru as the internal firewall can never be fully shutoff unless you are running your cisco switch as a DMZ
also are you connecting your other pc's to the cisco or to the 5890.
Instead of shutting off the firewall completely try enabling bridge mode and give your cisco the outside IP addy.
Posted on May 01, 2008
eduverna
  • 7 Answers
SOURCE: configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Posted on Apr 13, 2009
  • 10 Answers
SOURCE: want instructions on how to secure a zyxel prestige 900 router
I thought the 900 series zyxel was a multi ip address router modem, if your connecting a router or switch try supplying your gateway, dns info from your isp to the device.
raffaiel
  • 209 Answers
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Posted on Apr 26, 2009
garethmt
  • 116 Answers
SOURCE: ZyXel Prestige 660HW T1, power light blinking
It's dead, sorry. You could TRY removing the power cord, holding in the reset button and powering it back up with the button HELD DOWN for at least 10 seconds. That will factory default it, so I hope you know how to program it all again! (please don't contact me and complain if you don't...)
Posted on May 27, 2009
I need to access CCTV over internet.I am using Zyxel router (model P600R T1 v2) which having a static WAN IP provided by ISP.Can please guide me on the steps.Thanks.
first you need to forward TCP ports in your router pls write down which TCP ports used for video , audio and control in your DVR and configure to forward this tcp ports in your router
it can be do one step using disable the DMZ and it will make less sequrity in your internal network
Apr 11, 2013 | Zyxel Prestige 660HW Wireless Router...
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Network speed.
the speed of the network adaptor is 100mps but the system speed is constrained by the maximum speed that your broadband provider.
What is the rated speed of the internet connection to your home? this will be the limiting factor.
Jul 22, 2008 | Zyxel Prestige 650HW - ADSL Router...
I have a ZyXEL P-660HW-TI ADSL wireless router used as the gateway and wireless AP (also the wired ports are used for LAN). It has no VoIP ports. I do have a 2nd ADSL router (not used: no wireless, 1 LAN...
No because the VOIP need to be loged in first. if you have the voip first then the wireless router and you turned off the router dchp section part of the wireless modem then perhaps it will work, plus you need a voip account.
Jul 03, 2008 | Computers & Internet
Internet connection
Connect a computer to one of the lan ports 1-4.
Connect the adsl modem to "internet" or "wan" port of hub.
Open the hub's configuration page in your browser, usually this is http://192.168.1.1 Under Setup->Basic Setup, set the configuration for "Internet Connection Type " to "Automatic Configuration - DHCP". Under Network Setup, enable the hub's internal DHCP server so your lan hosts can get their ip's from the hub. Each local computer should have DHCP enabled. Your adsl modem must support DHCP for this to work, some do not. If it still doesnt work, try setting "PPPoE" instead of DHCP.
May 14, 2008 | Linksys Wireless-G WRT54GL Router
What do I need to use the P310?
You need a ADSL modem or cable modem with an Ethernet port to use the P310. The P310 has two Ethernet ports: LAN port and WAN port. You should connect the computer to the LAN port and connect the external modem to the WAN port. If the ISP uses PPPoE or RoadRunner Authentication you need the user account to enter in the P310.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
What is the Prestige 310 Internet Access Sharing Router?
The Prestige 310 Internet Access Sharing Router is a robust solution complete with everything needed for providing Internet access to multiple workstations through your cable or ADSL modem. The router equipped with 10Mbps Ethernet WAN port and an auto-sensing 10/100Mbps Etherent LAN port is the most simple and affordable solution for multiple and instant broadband Internet access. Virtually all-popular applications over Internet, such as Web, E-Mail, FTP, Telnet, Gopher, are supported. The Prestige 310 is designed for SOHO, branch offices, workgroups, and educational users.
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
