My webxam is built inside my computer how do i use it?
Abdul
Posted on Jan 03, 2013
    Problem Solver:
  • 13 Answers
You need a propper software to use the camera like Skype or you can visit http://www.chatroulette.com/ just to try the camera (you will need a moder web browser and flash plugin) any new has it
you are done
Posted on May 27, 2011
How do i move my built in camera?
Just on the off-chance you are not a troll, and genuinely cannot see that a camera that is built into the display device doesn't actually move on it's own, the straight answer is: you can't move your built-in camera because it's built-in! To change it's position, you would have to move the entire display unit.
If you want to have a webcam that is capable of changing to any position, you will need to purchase an external webcam. Your local Electronics/Computers shop can help you with that.
addendum: I do not see any information on the web, but it might be possible to rotate the webcam lens inside it's housing. Refer to your computer's user manual to see if that is possible *before* you start poking around and potentially damaging the device.
Oct 03, 2014 | Acer AZ5700-U4002 23-Inch All-In-One...
Ice built up inside unit
could be low on freon or contactor stuck on compressor
Feb 07, 2014 | American Standard Heating & Cooling
No sound/volume
Hi. That cpu has built in speaker?
if yes, please take a look inside your computer and check th speaker cable inside your computer is put into board or not. If pull out, put it into speaker socket.
Connect PC Internal Speakers to Motherboard
Jan 19, 2014 | Computers & Internet
How does the aspire m1202 connect to the internet
Depends on what you have. Normally computers connect with a wire (ethernet cable) that runs from the router/modem to the computer. Or they can connect wirelessly (no wire) with a wireless card that is built inside the computer on some of them or you can purchase a wireless usb adapter that plugs into the usb port.
Mar 30, 2012 | Computers & Internet
My laptop is DELL XPS M1330. It heats up and then slows down the machine.
Inside your computer, any dust acts as an "insulator", preventing the heat "radiator" inside your laptop from dissipating the built-up heat. So, remove the dust:
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Hold the can upright, and blow compressed-air into every hole and slot in your laptop.
Reconnect everything.
Apr 02, 2010 | Dell XPS M1330 Laptop
Please tell me what my modem is for a intel insider windows 2000
A modem that is on its own card in a computer is for dialup access to internet, via telephone lines. Other modems that do the same thing are built in to laptop computers, and always have a regular telephone-type plug on gthe computer. Dialup access is notoriously slow compared to Broadband (Cable/DSL) connections.
Sep 15, 2009 | Intel (272757) Modem
Computer is dead
Most of the time it's power supply failure.
1.A lot of computer owners fail to clean the inside of their computer, plus the power supply out, on a regular basis. I find this occurrence at my shop quite a lot.
Unplugging the computer from power, observing anti-static guidelines, and using a can of compressed air for computers would have prevented this.
Power supply's have a fan for cooling, as well as heatsink's inside. When these components collect dirt, dust, hair, and other foreign objects, the cooling capacity drops tremendously.
Heat = Wasted Energy
The power supply struggles to keep up with the demand of power needed, and eventually components inside it fail.
2.Most power supply's installed in a pre-built computer, are of a low grade of quality. (MOST. Generally pre-built computers manufactured in the last two years, have upgraded the quality of their power supply's, but not all of them)
Saves the computer manufacturer money. These power supply's have low quality components. Gauge of wire used is smaller than it should be, Electrolytic Capacitors are of an inferior grade, transformers are cheaply made, and the rectifier bridge is cheaply constructed, are a few examples.
3.Computers that are built by the owner, and are not pre-built, may have a cheap, or underrated power supply installed. You really have to check out reviews for power supply's on the internet, to see what quality it has. However there are some websites, that 'pump up' the review to stay in good standing with the power supply manufacturer. Generally, if the power supply price is cheap, so is the quality.
There are two other things to look at.
It may be the Power On switch that is behind the Power On button. These can go out.
It could be the motherboard. Most of the time it is Electrolytic Capacitors that are the 'weakest link'. Specifically the one's that surround the processor. These 'Caps' are Voltage Regulators for the processor. If even One is bad, the processor will not work.
No processor, No computer.
How to know if it's the power supply? Use a known, good, and compatible power supply for a test. [Compatible being that the power supply has the required power cables for the motherboard, and enough Wattage]
How to know if there are bad Electrolytic Capacitors on the motherboard?
This website has information, plus photos of bad capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
Sep 14, 2009 | Abit AV8 Motherboard
Built in memory full
Once the computer is restarted - look for the camera in My Computer - it'll show-up as a removable device. Browse & copy the files inside.
Aug 31, 2008 | Pentax Optio S4i Digital Camera
How do i attach a antenna to my acer aspire. if it just is built in my computer internally?
what antenna ?
for Aspire 3680, it already have antena for wireless.
that antena, 1 side is connected to wireless card, it's in the back of laptop, you need to open it (open the cover on the back).
the other side is inside the lcd panel, if you open the lcd cover, the antena is close to lcd latch.
if you mean other antena, i amnot sure if you can attached it with aspire 3680
May 17, 2008 | Acer Aspire 3680 Laptop
Stopped responding
Hi whata
Plug the external hard disk into another computer's USB 2.0 port. If the problem follows the device, then there is a failure either of the external hard disk enclosure or of the hard disk (inside the enclosure).
If yours is one that you built yourself, you can remove the hard drive from inside the enclosure and plug it directly into a desktop computer (or another external hard disk enclosure) to see if the problem follows. (If you need help w/ this, just let us know.)
If yours is a pre-built external hard disk (you bought it w/ the hard drive already built-in) then you'll (if you're inclined to do so) need to open the enclosure to get at the hard disk inside. This can be difficult. You may, depending upon the enclosure, need to damage the enclosure to get it opened up.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
