Hello.
Try unplugging the printer from the power, manually moving the cartridge box to the correct position and turning the printer back on.
Sometimes the printer looses its positioning of the heads and this can sometimes help.
Regards
GM
Unfortunatly it sounds like more of a internat hardware issue rather that a quick fix. try this link from HPhttp://h10010.www1.hp.com/ewfrf/wc/docum...
If this does not work then a trip to the service centre may be required
Regards
GM
I tried your first solution, but no dice I will visit the website you suggested. Thanks for your help. I greatly appreciate it.
Leading
cause of paper jams is debris/foreign objects that accidentally fell into the
paper feed area. Please follow steps below to fix the problem:
1.
Remove the sheets of paper from the feeder.
2.
Grab a flashlight and look inside the feeder for any debris or foreign objects.
3.
If you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder.
4.
If feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges.
5.
Check the cartridge area for any obstructions/debris in the cartridge carrier's
path or the paper path.
6.
If cartridge area is clear, close the cover.
7.
Re-brick your printer. Pull out the power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
the cartridge area for any obstructions/debris in the cartridge carrier's path
or the paper path.
6. If
7. Rebrick
(pull out power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds).
8. When the
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
Leading
1. Remove
2. Grab a
3. If
4. If
5. Check
or the paper path.
6. If
7. Rebrick
8. When the
again.
I have tried turning it on and off moving the ink cartridge to the home position. I keep getting the shutdown message and 0x610000f6 message. The paper feeder is what's really not working. I have checked to make sure there are no small pieces of paper causing any obstructions and as of yet there are none.
